Hi!
Is there any possibility to put envs_dir outside project root by default and maybe set other options in platformio.ini?
Something like:
[platformio]
envs_dir = /var/pio/${PROJECT_ROOT}
src_dir = ${PROJECT_NAME}_code
[env:myenv]
Robert
Hi!
Something like:
[platformio]
[env:myenv]
Robert
How about environment variables? See $PLATFORMIO_ENVS_DIR.
I read the doc’s twice but i don’t know how to use them in platformio.ini and i did not find the variable for project name.
env_dir is expanded to “/var/pio/%env%” (e.g: /var/pio/uno)
also i did not find how to make this default for a new project.
Robert
Environment variables don’t relate to platformio.ini. PlatformIO process them automatically. For example,
> export PLATFORMIO_ENVS_DIR=/var/pio/myproject
> pio run
Ah, these are real environment variables!
Thank you!
