Hi, I want to burn bootloader on my Arduino Uno with another Arduino Uno. I’ve looked up on how to do it in wiki and there’s written that I should do it with custom upload script, which I’ve done.
I want to flash Optiboot8 and Arduino IDE uses 2 commands to set it up (from what I understand first set’s fuses, unlock bit; second flashes the bootloader and sets lock bit). The problem is that I need some variables for the command (so I can easily change it without going over that long one liner), but I just cannot access them in the command (I can only do $UPLOAD_FLAGS) but if they’re not ones that I can find in the settings, they’re just blank.
Here’s the code:
[env:optiboot_uno]
build_type = debug
board_build.mcu = atmega328p
board_build.f_cpu = 16000000L
board_hardware.uart = uart0
board_hardware.oscillator = external
board_bootloader.file = /home/jirka/.arduino15/packages/Optiboot/hardware/avr/0.8.0/bootloaders/optiboot/optiboot_atmega328.hex
lfuse = 0xF7
hfuse = 0xDE
efuse = 0x05
lock_bits = 0x2F
unlock_bits = 0x3F
upload_port = /dev/ttyUSB0
upload_speed = 19200
upload_flags =
-C
-v
-p
$BOARD_MCU
-c
stk500v1
-P
$UPLOAD_PORT
-b
$UPLOAD_SPEED
-e
-Ulock:w:$unlock_bits:m
-Uefuse:w:$efuse:m
-Uhfuse:w:$hfuse:m
-Ulfuse:w:$lfuse:m
upload_flags2 =
-C
-v
-p
$BOARD_MCU
-c
stk500v1
-P
$UPLOAD_PORT
-b
$UPLOAD_SPEED
-Uflash:w:$file:i
-Ulock:w:$lock_bits:m
;upload_command = avrdude "-C/home/jirka/.arduino15/packages/arduino/tools/avrdude/6.0.1-arduino5/etc/avrdude.conf" -v -patmega328p -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xF7:m && avrdude "-C/home/jirka/.arduino15/packages/arduino/tools/avrdude/6.0.1-arduino5/etc/avrdude.conf" -v -patmega328p -cstk500v1 -P/dev/ttyUSB0 -b19200 "-Uflash:w:/home/jirka/.arduino15/packages/Optiboot/hardware/avr/0.8.0/bootloaders/optiboot/optiboot_atmega328.hex:i" -Ulock:w:0x2F:m
upload_command = avrdude $UPLOAD_FLAGS && avrdude $upload_flags2
