I have been working with adafruit’s atmelsam platform and I’m stuck on something.
The framework has its cortex_handler.c
, which has the Reset_Handler
function implementation.
What is the correct way of creating my custom Reset_Handler
without having to modify the framework itself? The thing is that if I modify the framework, I would need to branch it out and avoid feature atmelsam updates from adafruit.
Thanks!
Thanks.
Use Redirecting... on the
"type": "framework",
"optional": true,
"owner": "platformio",
"version": "~1.6.12"
"framework-arduino-samd": {
"optional": true,
"version": "~1.8.13"
"framework-arduino-samd-adafruit": {
"optional": true,
"version": "~1.7.10"
"framework-arduino-samd-seeed": {
"optional": true,
package and you’re good to go.
Hi Max, thanks for the input.
Would be lot easier if those calls were implemented as weak one’s.
For instance, the only weak call is the initVariant()
// Weak empty variant initialization function.
// May be redefined by variant files.
void initVariant() __attribute__((weak));
void initVariant() { }
Thanks again!
You might be interested in this comment, in which someone proposed an extra_script (for the STM32 framework) in which something similar (weak attributes) were added to the framework files automatically… maybe you could adapt it for your needs?
opened 05:24AM - 09 Sep 19 UTC
When using the [MySensors library](https://platformio.org/lib/show/548/MySensors… ), linking fails with...
.pio/build/genericSTM32F103CB/src/main.cpp.o: In function `premain()':
main.cpp:(.text.startup._Z7premainv+0x0): multiple definition of `premain()'
.pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o:main.cpp:(.text.startup._Z7premainv+0x0): first defined here
.pio/build/genericSTM32F103CB/src/main.cpp.o: In function `main':
main.cpp:(.text.startup.main+0x0): multiple definition of `main'
.pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o:main.cpp:(.text.startup.main+0x0): first defined here
... most likely due to the library also having a `premain()` and `main()` in the hal folder. On the Arduino IDE, using the rogerclarkmelbourne/Arduino_STM32 core it works just fine.
But on PlatformIO, with
[env:genericSTM32F103CB]
platform = ststm32
board = genericSTM32F103CB
board_build.core = maple
548 ; MySensors
and the LightSensor example (picked as one of the shorter ones which should 'just compile/work' for any board) - with the requisite `#include <Arduino.h>` addition - it fails to build. Adding `lib_archive = no` does not make any noticeable difference. The same code **will** compile successfully for an atmelavr/uno target with PlatformIO, even though it appears the same form of collision should be happening there also.
Forum ref: https://community.platformio.org/t/how-to-eliminate-conflicting-symbols-arduinoststm32-maple-mysensors-lib/9509
<details>
<summary>Click to expand - Arduino IDE Compile verbose log</summary>
/usr/share/arduino/arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/pfeerick/.arduino15/packages -hardware /home/pfeerick/Arduino/hardware -tools /usr/share/arduino/tools-builder -tools /home/pfeerick/.arduino15/packages -libraries /home/pfeerick/Arduino/libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=DFUUploadMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10809 -build-path /tmp/arduino_build_191534 -warnings=none -build-cache /tmp/arduino_cache_557302 -prefs=build.warn_data_percentage=75 -verbose /tmp/arduino_modified_sketch_736219/BatteryPoweredSensor.ino
/usr/share/arduino/arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/pfeerick/.arduino15/packages -hardware /home/pfeerick/Arduino/hardware -tools /usr/share/arduino/tools-builder -tools /home/pfeerick/.arduino15/packages -libraries /home/pfeerick/Arduino/libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=DFUUploadMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10809 -build-path /tmp/arduino_build_191534 -warnings=none -build-cache /tmp/arduino_cache_557302 -prefs=build.warn_data_percentage=75 -verbose /tmp/arduino_modified_sketch_736219/BatteryPoweredSensor.ino
Using board 'genericSTM32F103C' from platform in folder: /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1
Using core 'maple' from platform in folder: /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1
Detecting libraries used...
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/libraries/MySensors/MyASM.S -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM/EEPROM.cpp -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM/flash_stm32.c -o /dev/null
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src/SPI.cpp -o /dev/null
Generating function prototypes...
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp -o /tmp/arduino_build_191534/preproc/ctags_target_for_gcc_minus_e.cpp
/usr/bin/arduino-ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_191534/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp -o /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp.o
Compiling libraries...
Compiling library "MySensors"
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/libraries/MySensors/MyASM.S -o /tmp/arduino_build_191534/libraries/MySensors/MyASM.S.o
Compiling library "EEPROM"
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM/flash_stm32.c -o /tmp/arduino_build_191534/libraries/EEPROM/flash_stm32.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM/EEPROM.cpp -o /tmp/arduino_build_191534/libraries/EEPROM/EEPROM.cpp.o
Compiling library "SPI"
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c -I/home/pfeerick/Arduino/libraries/MySensors -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI/src/SPI.cpp -o /tmp/arduino_build_191534/libraries/SPI/SPI.cpp.o
Compiling core...
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/wirish/start.S -o /tmp/arduino_build_191534/core/wirish/start.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/wirish/syscalls.c -o /tmp/arduino_build_191534/core/wirish/syscalls.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/wirish/start_c.c -o /tmp/arduino_build_191534/core/wirish/start_c.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/wirish/boards_setup.cpp -o /tmp/arduino_build_191534/core/wirish/boards_setup.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/wirish/boards.cpp -o /tmp/arduino_build_191534/core/wirish/boards.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/board.cpp -o /tmp/arduino_build_191534/core/board.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/exc.S -o /tmp/arduino_build_191534/core/libmaple/exc.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/stm32f1/performance/isrs.S -o /tmp/arduino_build_191534/core/libmaple/stm32f1/performance/isrs.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/stm32f1/performance/vector_table.S -o /tmp/arduino_build_191534/core/libmaple/stm32f1/performance/vector_table.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/hooks.c -o /tmp/arduino_build_191534/core/hooks.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/spi.c -o /tmp/arduino_build_191534/core/libmaple/spi.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/rcc.c -o /tmp/arduino_build_191534/core/libmaple/rcc.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_mem.c -o /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_mem.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/timer.c -o /tmp/arduino_build_191534/core/libmaple/timer.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_init.c -o /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_init.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/dma.c -o /tmp/arduino_build_191534/core/libmaple/dma.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_regs.c -o /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_regs.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/itoa.c -o /tmp/arduino_build_191534/core/itoa.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/gpio_f1.c -o /tmp/arduino_build_191534/core/libmaple/gpio_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/exti.c -o /tmp/arduino_build_191534/core/libmaple/exti.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/avr/dtostrf.c -o /tmp/arduino_build_191534/core/avr/dtostrf.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/exti_f1.c -o /tmp/arduino_build_191534/core/libmaple/exti_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/i2c_f1.c -o /tmp/arduino_build_191534/core/libmaple/i2c_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/adc.c -o /tmp/arduino_build_191534/core/libmaple/adc.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/iwdg.c -o /tmp/arduino_build_191534/core/libmaple/iwdg.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/flash.c -o /tmp/arduino_build_191534/core/libmaple/flash.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/fsmc_f1.c -o /tmp/arduino_build_191534/core/libmaple/fsmc_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/adc_f1.c -o /tmp/arduino_build_191534/core/libmaple/adc_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/nvic.c -o /tmp/arduino_build_191534/core/libmaple/nvic.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usart_private.c -o /tmp/arduino_build_191534/core/libmaple/usart_private.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/dac.c -o /tmp/arduino_build_191534/core/libmaple/dac.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/bkp_f1.c -o /tmp/arduino_build_191534/core/libmaple/bkp_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/stm32f1/usb.c -o /tmp/arduino_build_191534/core/libmaple/usb/stm32f1/usb.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/systick.c -o /tmp/arduino_build_191534/core/libmaple/systick.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/gpio.c -o /tmp/arduino_build_191534/core/libmaple/gpio.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/stm32f1/usb_cdcacm.c -o /tmp/arduino_build_191534/core/libmaple/usb/stm32f1/usb_cdcacm.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/dma_f1.c -o /tmp/arduino_build_191534/core/libmaple/dma_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_core.c -o /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_core.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/timer_f1.c -o /tmp/arduino_build_191534/core/libmaple/timer_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/util.c -o /tmp/arduino_build_191534/core/libmaple/util.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usb/stm32f1/usb_reg_map.c -o /tmp/arduino_build_191534/core/libmaple/usb/stm32f1/usb_reg_map.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/rcc_f1.c -o /tmp/arduino_build_191534/core/libmaple/rcc_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/spi_f1.c -o /tmp/arduino_build_191534/core/libmaple/spi_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usart.c -o /tmp/arduino_build_191534/core/libmaple/usart.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/usart_f1.c -o /tmp/arduino_build_191534/core/libmaple/usart_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/pwr.c -o /tmp/arduino_build_191534/core/libmaple/pwr.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/stm32f1/util_hooks.c -o /tmp/arduino_build_191534/core/stm32f1/util_hooks.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/libmaple/i2c.c -o /tmp/arduino_build_191534/core/libmaple/i2c.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/WString.cpp -o /tmp/arduino_build_191534/core/WString.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/Stream.cpp -o /tmp/arduino_build_191534/core/Stream.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/wirish_digital.cpp -o /tmp/arduino_build_191534/core/wirish_digital.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/HardwareTimer.cpp -o /tmp/arduino_build_191534/core/HardwareTimer.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/wirish_math.cpp -o /tmp/arduino_build_191534/core/wirish_math.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/HardwareSerial.cpp -o /tmp/arduino_build_191534/core/HardwareSerial.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/ext_interrupts.cpp -o /tmp/arduino_build_191534/core/ext_interrupts.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/wirish_time.cpp -o /tmp/arduino_build_191534/core/wirish_time.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/pwm.cpp -o /tmp/arduino_build_191534/core/pwm.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/usb_serial.cpp -o /tmp/arduino_build_191534/core/usb_serial.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/stm32f1/wiring_pulse_f1.cpp -o /tmp/arduino_build_191534/core/stm32f1/wiring_pulse_f1.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/stm32f1/wirish_debug.cpp -o /tmp/arduino_build_191534/core/stm32f1/wirish_debug.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/wirish_analog.cpp -o /tmp/arduino_build_191534/core/wirish_analog.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/Print.cpp -o /tmp/arduino_build_191534/core/Print.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/sdio.cpp -o /tmp/arduino_build_191534/core/sdio.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/tone.cpp -o /tmp/arduino_build_191534/core/tone.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/wirish_shift.cpp -o /tmp/arduino_build_191534/core/wirish_shift.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/cxxabi-compat.cpp -o /tmp/arduino_build_191534/core/cxxabi-compat.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/IPAddress.cpp -o /tmp/arduino_build_191534/core/IPAddress.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/new.cpp -o /tmp/arduino_build_191534/core/new.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/stm32f1/wirish_digital_f1.cpp -o /tmp/arduino_build_191534/core/stm32f1/wirish_digital_f1.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10809 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DARDUINO_ARCH_STM32 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple -I/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/main.cpp -o /tmp/arduino_build_191534/core/main.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/HardwareSerial.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/HardwareTimer.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/IPAddress.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/Print.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/Stream.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/WString.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/avr/dtostrf.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/cxxabi-compat.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/ext_interrupts.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/hooks.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/itoa.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/adc.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/adc_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/bkp_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/dac.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/dma.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/dma_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/exc.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/exti.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/exti_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/flash.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/fsmc_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/gpio.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/gpio_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/i2c.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/i2c_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/iwdg.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/nvic.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/pwr.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/rcc.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/rcc_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/spi.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/spi_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/stm32f1/performance/isrs.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/stm32f1/performance/vector_table.S.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/systick.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/timer.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/timer_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usart.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usart_f1.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usart_private.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/stm32f1/usb.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/stm32f1/usb_cdcacm.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/stm32f1/usb_reg_map.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_core.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_init.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_mem.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/usb/usb_lib/usb_regs.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/libmaple/util.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/main.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/new.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/pwm.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/sdio.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/stm32f1/util_hooks.c.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/stm32f1/wiring_pulse_f1.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/stm32f1/wirish_debug.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/stm32f1/wirish_digital_f1.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/tone.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/usb_serial.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/wirish_analog.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/wirish_digital.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/wirish_math.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/wirish_shift.cpp.o
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/arduino_build_191534/core/core.a /tmp/arduino_build_191534/core/wirish_time.cpp.o
Archiving built core (caching) in: /tmp/arduino_cache_557302/core/core_58c583a5d3d773d2327b668eb3f10984.a
Linking everything together...
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -Os -Wl,--gc-sections -mcpu=cortex-m3 -T/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/ld/bootloader_20.ld -Wl,-Map,/tmp/arduino_build_191534/BatteryPoweredSensor.ino.map -L/home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/variants/generic_stm32f103c/ld -o /tmp/arduino_build_191534/BatteryPoweredSensor.ino.elf -L/tmp/arduino_build_191534 -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group /tmp/arduino_build_191534/sketch/BatteryPoweredSensor.ino.cpp.o /tmp/arduino_build_191534/libraries/MySensors/MyASM.S.o /tmp/arduino_build_191534/libraries/EEPROM/EEPROM.cpp.o /tmp/arduino_build_191534/libraries/EEPROM/flash_stm32.c.o /tmp/arduino_build_191534/libraries/SPI/SPI.cpp.o /tmp/arduino_build_191534/core/board.cpp.o /tmp/arduino_build_191534/core/wirish/boards.cpp.o /tmp/arduino_build_191534/core/wirish/boards_setup.cpp.o /tmp/arduino_build_191534/core/wirish/start.S.o /tmp/arduino_build_191534/core/wirish/start_c.c.o /tmp/arduino_build_191534/core/wirish/syscalls.c.o /tmp/arduino_build_191534/core/core.a -Wl,--end-group
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy -O binary /tmp/arduino_build_191534/BatteryPoweredSensor.ino.elf /tmp/arduino_build_191534/BatteryPoweredSensor.ino.bin
Using library MySensors at version 2.3.1 in folder: /home/pfeerick/Arduino/libraries/MySensors
Using library EEPROM in folder: /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/EEPROM (legacy)
Using library SPI at version 1.0 in folder: /home/pfeerick/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI
/home/pfeerick/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-size -A /tmp/arduino_build_191534/BatteryPoweredSensor.ino.elf
Sketch uses 45728 bytes (69%) of program storage space. Maximum is 65536 bytes.
Global variables use 4632 bytes (22%) of dynamic memory, leaving 15848 bytes for local variables. Maximum is 20480 bytes.
</details>
<details>
<summary>Click to expand - PlatformIO Verbose Build log</summary>
Processing genericSTM32F103CB (platform: ststm32; framework: arduino; board: genericSTM32F103CB; board_build.core: maple; lib_deps: 548)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103CB.html
PLATFORM: ST STM32 5.6.0 > STM32F103CB (20k RAM. 128k Flash)
HARDWARE: STM32F103CBT6 72MHz, 20KB RAM, 128KB Flash
DEBUG: Current (blackmagic) External (blackmagic, jlink, stlink)
PACKAGES: toolchain-gccarmnoneeabi 1.70201.0 (7.2.1), framework-arduinoststm32-maple 1.10000.190819 (1.0.0)
Found 33 compatible libraries
|-- <MySensors> 2.3.1 (/home/pfeerick/Documents/PlatformIO/Projects/STM32/MySensors/.pio/libdeps/genericSTM32F103CB/MySensors_ID548)
| |-- <SPI> 1.0 (/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI)
| |-- <Wire> 1.0 (/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire)
| |-- <EEPROM> (/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM)
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/board.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/board.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/boards.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/wirish/boards.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/boards_setup.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/wirish/boards_setup.cpp
arm-none-eabi-gcc -x assembler-with-cpp -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c -c -o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/start.S.o /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/wirish/start.S
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/start_c.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/wirish/start_c.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/syscalls.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/wirish/syscalls.c
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/HardwareSerial.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/HardwareSerial.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/HardwareTimer.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/HardwareTimer.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/IPAddress.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/IPAddress.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/Print.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/Print.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/Stream.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/Stream.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/WString.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/WString.cpp
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/avr/dtostrf.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/avr/dtostrf.c
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/cxxabi-compat.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/cxxabi-compat.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/ext_interrupts.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/ext_interrupts.cpp
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/hooks.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/hooks.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/itoa.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/itoa.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/adc.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/adc.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/adc_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/adc_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/bkp_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/bkp_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/dac.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/dac.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/dma.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/dma.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/dma_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/dma_f1.c
arm-none-eabi-gcc -x assembler-with-cpp -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c -c -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/exc.S.o /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/exc.S
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/exti.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/exti.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/exti_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/exti_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/flash.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/flash.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/fsmc_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/fsmc_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/gpio.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/gpio.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/gpio_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/gpio_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/i2c.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/i2c.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/i2c_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/i2c_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/iwdg.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/iwdg.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/nvic.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/nvic.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/pwr.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/pwr.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/rcc.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/rcc.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/rcc_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/rcc_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/spi.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/spi.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/spi_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/spi_f1.c
arm-none-eabi-gcc -x assembler-with-cpp -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c -c -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/stm32f1/performance/isrs.S.o /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/stm32f1/performance/isrs.S
arm-none-eabi-gcc -x assembler-with-cpp -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c -c -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/stm32f1/performance/vector_table.S.o /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/stm32f1/performance/vector_table.S
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/systick.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/systick.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/timer.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/timer.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/timer_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/timer_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usart.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usart.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usart_f1.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usart_f1.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usart_private.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usart_private.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/stm32f1/usb.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/stm32f1/usb.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/stm32f1/usb_cdcacm.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/stm32f1/usb_cdcacm.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/stm32f1/usb_reg_map.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/stm32f1/usb_reg_map.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_core.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_core.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_init.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_init.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_mem.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_mem.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_regs.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/usb/usb_lib/usb_regs.c
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/util.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/libmaple/util.c
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/main.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/new.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/new.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/pwm.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/pwm.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/sdio.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/sdio.cpp
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/util_hooks.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/stm32f1/util_hooks.c
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/wiring_pulse_f1.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/stm32f1/wiring_pulse_f1.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/wirish_debug.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/stm32f1/wirish_debug.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/wirish_digital_f1.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/stm32f1/wirish_digital_f1.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/tone.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/tone.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/usb_serial.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/usb_serial.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_analog.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/wirish_analog.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_digital.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/wirish_digital.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_math.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/wirish_math.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_shift.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/wirish_shift.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_time.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple/wirish_time.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/src/main.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -Iinclude -Isrc -I.pio/libdeps/genericSTM32F103CB/MySensors_ID548 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/utility -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c src/main.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/lib52c/SPI/SPI.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/libcf8/Wire/SoftWire.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/utility -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/SoftWire.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/libcf8/Wire/Wire.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/utility -I/home/pfeerick/.platformio/packages/f/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp: In member function 'uint16_t SPIClass::transfer16(uint16_t) const':
r/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp:383:5: warning: this 'while' clause does not guard... [-Wmisleading-indentation]
a while (spi_is_busy(spi_d) != 0); // wait until BSY=0
me/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp:384:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'while'
w uint16_t ret = spi_rx_reg(spi_d)<<8; // read and shift high byte
o ^~~~r~k~-~a~r
d/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp:387:5: warning: this 'while' clause does not guard... [-Wmisleading-indentation]
u while (spi_is_busy(spi_d) != 0); // wait until BSY=0
i ^~~~n~o
s/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp:388:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'while'
t ret += spi_rx_reg(spi_d); // read low byte
s ^~~
t/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp: In function 'spi_baud_rate determine_baud_rate(spi_dev*, uint32_t)':
m/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.cpp:778:12: warning: enumeration value 'RCC_AHB' not handled in switch [-Wswitch]
3 switch (rcc_dev_clk(dev->clk_id))
2 ^
-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/Wire.cpp
In file included from .pio/libdeps/genericSTM32F103CB/MySensors_ID548/hal/transport/RF24/driver/RF24.h:109:0,
from .pio/libdeps/genericSTM32F103CB/MySensors_ID548/hal/transport/RF24/driver/RF24.cpp:23,
from .pio/libdeps/genericSTM32F103CB/MySensors_ID548/MySensors.h:364,
from src/main.cpp:38:
/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.h:168:15: warning: '_spi2_this' defined but not used [-Wunused-variable]
static void (*_spi2_this);
/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.h:165:15: warning: '_spi1_this' defined but not used [-Wunused-variable]
static void (*_spi1_this);
/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src/SPI.h:163:16: warning: 'ff' defined but not used [-Wunused-variable]
static uint8_t ff = 0XFF;
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/libcf8/Wire/utility/WireBase.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/utility -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/utility/WireBase.cpp
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/lib354/EEPROM/EEPROM.cpp.o -c -std=gnu++11 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM/EEPROM.cpp
arm-none-eabi-ar rc .pio/build/genericSTM32F103CB/lib52c/libSPI.a .pio/build/genericSTM32F103CB/lib52c/SPI/SPI.cpp.o
arm-none-eabi-ranlib .pio/build/genericSTM32F103CB/lib52c/libSPI.a
arm-none-eabi-gcc -o .pio/build/genericSTM32F103CB/lib354/EEPROM/flash_stm32.c.o -c -std=gnu11 -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -Os -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c /home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM/flash_stm32.c
arm-none-eabi-ar rc .pio/build/genericSTM32F103CB/libcf8/libWire.a .pio/build/genericSTM32F103CB/libcf8/Wire/SoftWire.cpp.o .pio/build/genericSTM32F103CB/libcf8/Wire/Wire.cpp.o .pio/build/genericSTM32F103CB/libcf8/Wire/utility/WireBase.cpp.o
arm-none-eabi-ranlib .pio/build/genericSTM32F103CB/libcf8/libWire.a
arm-none-eabi-gcc -x assembler-with-cpp -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections -nostdlib -march=armv7-m --param max-inline-insns-single=500 -Wall -DPLATFORMIO=40100 -DSTM32F103xB -DSTM32F1 -DARDUINO=10808 -DARDUINO_ARCH_STM32 -DARDUINO_ARCH_STM32F1 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -D__STM32F1__ -DBOARD_generic_stm32f103c -DF_CPU=72000000L -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -I.pio/libdeps/genericSTM32F103CB/MySensors_ID548 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/EEPROM -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/Wire/utility -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/libraries/SPI/src -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/stm32f1 -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/usb/usb_lib -I/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c -c -o .pio/build/genericSTM32F103CB/libc36/MySensors_ID548/MyASM.S.o .pio/libdeps/genericSTM32F103CB/MySensors_ID548/MyASM.S
arm-none-eabi-ar rc .pio/build/genericSTM32F103CB/libc36/libMySensors_ID548.a .pio/build/genericSTM32F103CB/libc36/MySensors_ID548/MyASM.S.o
arm-none-eabi-ranlib .pio/build/genericSTM32F103CB/libc36/libMySensors_ID548.a
arm-none-eabi-ar rc .pio/build/genericSTM32F103CB/lib354/libEEPROM.a .pio/build/genericSTM32F103CB/lib354/EEPROM/EEPROM.cpp.o .pio/build/genericSTM32F103CB/lib354/EEPROM/flash_stm32.c.o
arm-none-eabi-ranlib .pio/build/genericSTM32F103CB/lib354/libEEPROM.a
arm-none-eabi-g++ -o .pio/build/genericSTM32F103CB/firmware.elf -T jtag.ld -Os -mthumb -mcpu=cortex-m3 -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/board.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/boards.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/boards_setup.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/start.S.o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/start_c.c.o .pio/build/genericSTM32F103CB/FrameworkArduinoVariant/wirish/syscalls.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/HardwareSerial.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/HardwareTimer.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/IPAddress.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/Print.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/Stream.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/WString.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/avr/dtostrf.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/cxxabi-compat.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/ext_interrupts.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/hooks.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/itoa.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/adc.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/adc_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/bkp_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/dac.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/dma.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/dma_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/exc.S.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/exti.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/exti_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/flash.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/fsmc_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/gpio.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/gpio_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/i2c.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/i2c_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/iwdg.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/nvic.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/pwr.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/rcc.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/rcc_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/spi.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/spi_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/stm32f1/performance/isrs.S.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/stm32f1/performance/vector_table.S.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/systick.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/timer.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/timer_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usart.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usart_f1.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usart_private.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/stm32f1/usb.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/stm32f1/usb_cdcacm.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/stm32f1/usb_reg_map.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_core.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_init.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_mem.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/usb/usb_lib/usb_regs.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/libmaple/util.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/new.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/pwm.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/sdio.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/util_hooks.c.o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/wiring_pulse_f1.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/wirish_debug.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/stm32f1/wirish_digital_f1.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/tone.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/usb_serial.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_analog.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_digital.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_math.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_shift.cpp.o .pio/build/genericSTM32F103CB/FrameworkArduino/wirish_time.cpp.o .pio/build/genericSTM32F103CB/src/main.cpp.o -L/home/pfeerick/.platformio/platforms/ststm32/ldscripts -L.pio/build/genericSTM32F103CB -L/home/pfeerick/.platformio/packages/framework-arduinoststm32-maple/STM32F1/variants/generic_stm32f103c/ld -Wl,--start-group .pio/build/genericSTM32F103CB/lib52c/libSPI.a .pio/build/genericSTM32F103CB/libcf8/libWire.a .pio/build/genericSTM32F103CB/lib354/libEEPROM.a .pio/build/genericSTM32F103CB/libc36/libMySensors_ID548.a -lm -lgcc -Wl,--end-group
.pio/build/genericSTM32F103CB/src/main.cpp.o: In function `premain()':
main.cpp:(.text.startup._Z7premainv+0x0): multiple definition of `premain()'
.pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o:main.cpp:(.text.startup._Z7premainv+0x0): first defined here
.pio/build/genericSTM32F103CB/src/main.cpp.o: In function `main':
main.cpp:(.text.startup.main+0x0): multiple definition of `main'
.pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o:main.cpp:(.text.startup.main+0x0): first defined here
.pio/build/genericSTM32F103CB/FrameworkArduino/main.cpp.o: In function `main':
main.cpp:(.text.startup.main+0x2): warning: undefined reference to `setup()'
*** [.pio/build/genericSTM32F103CB/firmware.elf] Error 1
========================== [FAILED] Took 5.90 seconds ==========================
Environment Status Duration
genericSTM32F103CB FAILED 00:00:05.902
atmelavr IGNORED
==================== 1 failed, 0 succeeded in 00:00:05.902 ====================
</details>
