I am trying to get esp8266 framework v3.0.0 to work. I’ve got it working in classic Arduino IDE, but I want to use it in Platform IO, as I love both VSCode and PIO. But unfortunately, it seems like framework is working OK, but the tools do not change - in result I’m getting compilation errors about C++17.
Repro steps are:
- Create new empty project for Wemos D1 Mini, for ESP8266 Arduino Platform
- Add custom framework to platformio.ini
[env:d1_mini]
platform = espressif8266
board = d1_mini
platform_packages =
framework-arduinoespressif8266 @ GitHub - esp8266/Arduino: ESP8266 core for Arduino
- Try to compile
- Get
Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: <I cannot post links....> PLATFORM: Espressif 8266 2.6.2 > WeMos D1 R2 and mini HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash PACKAGES: - framework-arduinoespressif8266 e636a65 - tool-esptool 1.413.0 (4.13) - tool-esptoolpy 1.20800.0 (2.8.0) - tool-mklittlefs 1.203.200522 (2.3) - tool-mkspiffs 1.200.0 (2.0) - toolchain-xtensa 2.40802.200502 (4.8.2) LDF: Library Dependency Finder -> <I cannot post links....> LDF Modes: Finder ~ chain, Compatibility ~ soft Found 43 compatible libraries Scanning dependencies... No dependencies Building in release mode Generating .pio\build\d1_mini\core\core_version.h Generating LD script .pio\build\d1_mini\ld\local.eagle.app.v6.common.ld Archiving .pio\build\d1_mini\libFrameworkArduinoVariant.a fatal: No names found, cannot describe anything. Compiling .pio\build\d1_mini\FrameworkArduino\StackThunk.cpp.o Compiling .pio\build\d1_mini\FrameworkArduino\WMath.cpp.o xtensa-lx106-elf-g++: error: unrecognized command line option '-std=gnu++17' xtensa-lx106-elf-g++: error: unrecognized command line option '-std=gnu++17' Compiling .pio\build\d1_mini\FrameworkArduino\cbuf.cpp.o Compiling .pio\build\d1_mini\FrameworkArduino\cont.S.o xtensa-lx106-elf-g++: error: unrecognized command line option '-std=gnu++17' Compiling .pio\build\d1_mini\FrameworkArduino\cont_util.cpp.o *** [.pio\build\d1_mini\FrameworkArduino\StackThunk.cpp.o] Error 1 *** [.pio\build\d1_mini\FrameworkArduino\WMath.cpp.o] Error 1 *** [.pio\build\d1_mini\FrameworkArduino\cbuf.cpp.o] Error 1 xtensa-lx106-elf-g++: error: unrecognized command line option '-std=gnu++17' *** [.pio\build\d1_mini\FrameworkArduino\cont_util.cpp.o] Error 1
Is there a way to force custom tools as well?
