Due to the nature of our project we have to run a custom fork of esp-idf in order to support a larger number of SPI Devices, this in and of itself works fine in an environment where we are purely running esp-idf and compiling/flashing using idf.py
However we are now attempting to use that same fork of esp-idf in pio and we are getting these errors:
TypeError: can only concatenate str (not "NoneType") to str:
File "/root/.platformio/penv/lib/python3.8/site-packages/platformio/builder/main.py", line 173:
File "/root/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Script/SConscript.py", line 609:
File "/root/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Script/SConscript.py", line 279:
File "/root/.platformio/platforms/espressif32/builder/main.py", line 346:
File "/root/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Util/envs.py", line 251:
File "/root/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/piobuild.py", line 61:
env.ProcessProgramDeps()
File "/root/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/piobuild.py", line 121:
File "/root/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/piobuild.py", line 347:
SConscript(env.GetFrameworkScript(name), exports="env")
File "/root/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Script/SConscript.py", line 673:
return method(*args, **kw)
File "/root/.platformio/platforms/espressif32/builder/frameworks/espidf.py", line 1251:
ensure_python_venv_available()
File "/root/.platformio/platforms/espressif32/builder/frameworks/espidf.py", line 1224:
venv_dir = get_idf_venv_dir()
File "/root/.platformio/platforms/espressif32/builder/frameworks/espidf.py", line 1178:
env.subst("$PROJECT_CORE_DIR"), "penv", ".espidf-" + idf_version
This is our platformio.ini:
[platformio]
default_envs = esp32s3dev
[common]
-D ESP_PLATFORM=1
-D USE_STL
extra_scripts = pre:Build_Tool/preScript.py
[env:esp32s3dev]
framework = espidf
board = esp32s3dev
-I"lib"
-I"Types"
platform_packages =
framework-espidf@https://github.com/OEKOSOLVE-FORKS/esp-idf.git#releaseOS/v5.2_modified
We are unsure where our mistake is (if any) as according to all information I was able to find, we should be doing things correctly.
