I’m encountering a build error while compiling a project with a custom similar to Rumba32 board using the STM32 platform and the ARM GCC toolchain in PlatformIO. The build fails with multiple “undefined reference” errors related to PinMap_TIM, SystemClock_Config, digitalPin, and others.
Here are the warnings and the error :
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/SrcWrapper/src/stm32/analog.cpp.o: in function `pwm_stop':
analog.cpp:(.text.pwm_stop+0x58): undefined reference to `PinMap_TIM'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/SrcWrapper/src/stm32/hw_config.c.o: in function `hw_config_init':
hw_config.c:(.text.hw_config_init+0x12): undefined reference to `SystemClock_Config'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(usbd_if.c.o): in function `USBD_SystemClockConfigFromResume':
usbd_if.c:(.text.USBD_SystemClockConfigFromResume+0xa): undefined reference to `SystemClock_Config'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(wiring_digital.c.o): in function `pinMode':
wiring_digital.c:(.text.pinMode+0xb4): undefined reference to `digitalPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xbc): undefined reference to `PinMap_TIM'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xc0): undefined reference to `analogInputPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(wiring_digital.c.o): in function `digitalWrite':
wiring_digital.c:(.text.digitalWrite+0x64): undefined reference to `digitalPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalWrite+0x70): undefined reference to `analogInputPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(wiring_digital.c.o): in function `digitalRead':
wiring_digital.c:(.text.digitalRead+0x64): undefined reference to `digitalPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalRead+0x70): undefined reference to `analogInputPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(usbd_conf.c.o): in function `HAL_PCD_MspInit':
usbd_conf.c:(.text.HAL_PCD_MspInit+0x118): undefined reference to `PinMap_USB_OTG_FS'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: usbd_conf.c:(.text.HAL_PCD_MspInit+0x128): undefined reference to `PinMap_USB_OTG_HS'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(HardwareSerial.cpp.o): in function `HardwareSerial::setRx(unsigned long)':
HardwareSerial.cpp:(.text._ZN14HardwareSerial5setRxEm+0x40): undefined reference to `digitalPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: HardwareSerial.cpp:(.text._ZN14HardwareSerial5setRxEm+0x44): undefined reference to `analogInputPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(HardwareSerial.cpp.o): in function `HardwareSerial::setTx(unsigned long)':
HardwareSerial.cpp:(.text._ZN14HardwareSerial5setTxEm+0x40): undefined reference to `digitalPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: HardwareSerial.cpp:(.text._ZN14HardwareSerial5setTxEm+0x44): undefined reference to `analogInputPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libFrameworkArduino.a(HardwareSerial.cpp.o): in function `HardwareSerial::HardwareSerial(void*, HalfDuplexMode_t)':
HardwareSerial.cpp:(.text._ZN14HardwareSerialC2EPv16HalfDuplexMode_t+0x6c): undefined reference to `PinMap_UART_RX'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: HardwareSerial.cpp:(.text._ZN14HardwareSerialC2EPv16HalfDuplexMode_t+0x70): undefined reference to `PinMap_UART_TX'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/rumba_custom/libf64/libSPI.a(SPI.cpp.o): in function `SPIClass::SPIClass()':
SPI.cpp:(.text._ZN8SPIClassC2Ev+0x54): undefined reference to `analogInputPin'
c:/users/cedella/.platformio/packages/toolchain-gccarmnoneeabi@1.90201.191206/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: SPI.cpp:(.text._ZN8SPIClassC2Ev+0x58): undefined reference to `digitalPin'
*** [.pio\build\rumba_custom\firmware.elf] Error 1
It seems like the linker is unable to find references for several STM32-related functions and variables. I’m using a custom board configuration for the Rumba, and it seems like some essential STM32 HAL functions (like SystemClock_Config) and pin mapping references (PinMap_TIM, digitalPin, etc.) are missing or not properly linked.
What I did to configure my custom board:
- I created a folder called “boards” in the root of my project, containing the JSON file for the custom board named
rumba_custom.json.
"build": {
"cpu": "cortex-m4",
"extra_flags": "-DSTM32F446xx",
"f_cpu": "180000000L",
"framework_extra_flags": {
"arduino": "-DCUSTOM_PERIPHERAL_PINS"
"mcu": "stm32f446ret6",
"product_line": "STM32F446xx",
"variant": "STM_CUSTOM"
"connectivity": [
"can"
"debug": {
"jlink_device": "STM32F446RE",
"openocd_target": "stm32f4x",
"svd_path": "STM32F446x.svd"
"frameworks": [
"arduino",
"cmsis",
"stm32cube",
"libopencm3"
"name": "3D Printer control board",
"upload": {
"maximum_ram_size": 131072,
"maximum_size": 524288,
"protocol": "stlink",
"protocols": [
"jlink",
"cmsis-dap",
"stlink",
"blackmagic",
"serial"
"url": "https://github.com/Aus3D/RUMBA32",
"vendor": "RUMBA"
- I created a folder called “variants” in the same location, with another folder inside it named “STM_CUSTOM”. In this folder, I placed the variant files as well as the
PeripheralPinsfiles. - I modified the
platformio.inifile as follows:
[env:rumba_custom]
platform = ststm32@15.4.1
extends = env:FYSETC_S6
board = rumba_custom
board_build.ldscript = my_linkerscript.ld
board_build.offset = 0x8000
board_upload.offset_address = 0x08008000
upload_protocol = dfu
https://github.com/RudolphRiedel/FT800-FT813/archive/refs/heads/5.x.zip
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
-D EVE_RiTFT50
-D EVE_CS=PC6
-D EVE_PDN=PC7
-I variants/STM_CUSTOM
-D ARDUINO_RUMBA32
monitor_dtr = 1
Has anyone encountered a similar issue or know how to resolve these undefined reference errors?
Thank you!
