Custom board json
I want to create a custom JSON file for my board in order to not copy each time my custom environnement which the following :
platformio.ini
[platformio]
;default_envs = KZV3_
boards_dir =..\..\board
[common_env_data]
lib_extra_dirs =
    ..\..\lib ;shared librarie
[env:custom] ; env :program_via_AVRISP_mkII Kaizenboard V3.1
platform = ${common_env_data.platform}
board = ATmega328P
board_hardware.oscillator = external ; added
board_build.f_cpu = 4000000L ;added 4 MHz
framework = ${common_env_data.framework}
monitor_port = ${env:ATmega328P.upload_port}
build_flags = -DKZ_V3 -DDEBUG -DBoard_1_8V
upload_speed = 9600 ;recommended for 4 MHz
upload_port = COM3
upload_protocol= custom
upload_flags =
   -C
   -p
   $BOARD_MCU
   -P
   $UPLOAD_PORT
   -c
   arduino ; test  stk500v2
   -b
   $UPLOAD_SPEED
lib_extra_dirs = ${common_env_data.lib_extra_dirs} ;shared librarie
I created a json file in a board folder. I am able to use the board declare in the json.
My issue is the following, I don’t know if it is possible to remove all the board and upload declaration.
And if it is possible how ?
I make research and it seems that the easiest implementation would be by using a python script. Is there another way to use custom avrdude upload protocol whitout writing it in ini with all the flag.
Maybe I have missed something in the documentation ?
Thanks for your help
Clement
Isn’t that the standard upload configuration? That is already set at
so I don’t think you need that upload_x flags, except for upload_speed = 9600 at all.
You can put some of these options in the board JSON but not all. E.g.,
build_flags can be done via extra_flags, upload_protocol via protocol, upload_speed via spede, f_cpu via f_cpu, but not board_hardware.oscillator = external and the others.
Thanks I made some tests by putting with speed in the json but it didn’t worked.
It may be because arduino protocol overwrite my 9600 baud for upload speed.
I will try some of the hint you gave me.
I agree about the fact that my custom protocol is almost standard but i didn’t understand everything.My project used to be on arduino with a programmer via AVRISP mkII.
So I used the env [env:program_via_AVRISP_mkII] from documentation : Atmel AVR — PlatformIO latest documentation
Except that stk500v2 wasn’t working so I have used arduino instead.
No, that should not be the case. Execute the project task “Advanced → Verbose Upload” to see the exact avrdude invocation. It should contain the -b 9600 flag if the upload speed is set up correctly, either via the platformio.ini or a custom board definition (which you must also refer to with the board = <name of json file> directive).
Result without specifying arduino programmer :
Even if my custom.json say :
“upload”: {
“maximum_ram_size”: 2048,
“maximum_size”: 32768,
“protocol”: “arduino”,
Complete json
“build”: {
“core”: “MiniCore”,
“extra_flags”: “-DARDUINO_AVR_ATmega328P -DKZ_V3 -DBoard_1_8V”,
“f_cpu”: “4000000L”,
“mcu”: “atmega328p”,
“variant”: “standard”
“bootloader”: {
“led_pin”: “B5”
“debug”: {
“simavr_target”: “atmega328p”,
“avr-stub”: {
“speed”: 115200
“frameworks”: [
“arduino”
“name”: “ATmega328P/PA”,
“upload”: {
“require_upload_port”: true,
“speed”: 9600
“url”: “ATmega328P - 8-bit AVR Microcontrollers”,
“vendor”: “Microchip”
Maybe I can specificy in the json under upload section :
programmer : arduino,
That is really weird because according to the code
it should add -c arduino to the flags since $UPLOAD_PROTOCOL is arduino.
What is the current platformio.ini?
Do you mean the full ini ?
`platformio.ini`
[platformio]
[common_env_data]
lib_extra_dirs =
[env:uno]
board = uno
lib_extra_dirs =${common_env_data.lib_extra_dirs} ;shared librarie
;test_ignore = test_misc
>[env:KZV3_1] ; env :program_via_AVRISP_mkII Kaizenboard V3.1
framework =${common_env_data.framework}
board = KZV3_1
upload_port = COM3
upload_flags =
   -C
   -p
   $BOARD_MCU
   -P
   $UPLOAD_PORT
   -c
   arduino
   -b
   $UPLOAD_SPEED
>[env:KZV3_Origin] ; env :program_via_AVRISP_mkII Kaizenboard V3.1
board = ATmega328P
upload_port = COM3
upload_flags =
   -C
   -p
   $BOARD_MCU
   -P
   $UPLOAD_PORT
   -c
   -b
   $UPLOAD_SPEED
KZV3_origin is the regular atmega file and KZV3_1 is the json one.
You should try without those.
It seems to work fine without them even if they are written in the documentation : Atmel AVR — PlatformIO latest documentation
Thanks a lot !
I will look more deeply into them to understand what they were supposed to do.
I look more deeply on how upload and bootloader work with atmega board.
Apparently by writing that the board is a atmega, it will automaticaly go for tool avrdude
Example from my upload test :
  • avrdude -v -p atmega328p -C C:\packages\tool-avrdude\avrdude.conf -c arduino -b 9600 -D -P COM3 -U flash:w:.pio\build\KZV3\firmware.hex:i
