Previously compiling custom board (defined in /boards/name.json) no longer compiling. Was able to re-create the issue from scratch with a fresh project following these instructions: Custom Embedded Boards — PlatformIO latest documentation and copying the referenced boards definition json from the linked article here: https://github.com/platformio/platform-nxplpc/blob/develop/examples/mbed-custom-target/boards/my_custom_board.json
when in build; i get the following error:
IndexError: list index out of range:
File "/Users/pinchy/.platformio/penv/lib/python2.7/site-packages/platformio/builder/main.py", line 156:
File "/Users/pinchy/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 541:
File "/Users/pinchy/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "/Users/pinchy/.platformio/platforms/nordicnrf52/builder/main.py", line 193:
File "/Users/pinchy/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 224:
File "/Users/seb/.platformio/penv/lib/python2.7/site-packages/platformio/builder/tools/platformio.py", line 61:
env.ProcessProgramDeps()
File "/Users/seb/.platformio/penv/lib/python2.7/site-packages/platformio/builder/tools/platformio.py", line 118:
File "/Users/seb/.platformio/penv/lib/python2.7/site-packages/platformio/builder/tools/platformio.py", line 330:
SConscript(env.GetFrameworkScript(f), exports="env")
File "/Users/pinchy/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 604:
return method(*args, **kw)
File "/Users/pinchy/.platformio/platforms/nordicnrf52/builder/frameworks/arduino.py", line 31:
env.SConscript("arduino/nrf5.py")
File "/Users/pinchy/.platformio/platforms/nordicnrf52/builder/frameworks/arduino/nrf5.py", line 158:
mcu_family = board.get("build.arduino.ldscript", "").split("_")[1]
When I run pio boards
in terminal, the following error message appears:
File "/Library/Python/2.7/site-packages/platformio/__main__.py", line 102, in main
File "/Library/Python/2.7/site-packages/click/core.py", line 700, in __call__
File "/Library/Python/2.7/site-packages/click/core.py", line 680, in main
rv = self.invoke(ctx)
File "/Library/Python/2.7/site-packages/platformio/commands/__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "/Library/Python/2.7/site-packages/click/core.py", line 1027, in invoke
File "/Library/Python/2.7/site-packages/click/core.py", line 873, in invoke
File "/Library/Python/2.7/site-packages/click/core.py", line 508, in invoke
return callback(*args, **kwargs)
File "/Library/Python/2.7/site-packages/platformio/commands/boards.py", line 34, in cli
for board in _get_boards(installed):
File "/Library/Python/2.7/site-packages/platformio/commands/boards.py", line 75, in _get_boards
return pm.get_installed_boards() if installed else pm.get_all_boards()
File "/Library/Python/2.7/site-packages/platformio/managers/platform.py", line 205, in get_all_boards
boards = self.get_installed_boards()
File "/Library/Python/2.7/site-packages/platformio/util.py", line 59, in wrapper
self.cache[key] = (time.time(), func(*args, **kwargs))
File "/Library/Python/2.7/site-packages/platformio/managers/platform.py", line 194, in get_installed_boards
for config in p.get_boards().values():
File "/Users/seb/.platformio/platforms/atmelsam/platform.py", line 98, in get_boards
result[key] = self._add_default_debug_tools(result[key])
File "/Users/seb/.platformio/platforms/atmelsam/platform.py", line 141, in _add_default_debug_tools
assert openocd_chipname
AssertionError
I have a work-around (to override an existing boards definition with my custom variants), but that’s not ideal. Any ideas?
