Creating new ESP-IDF project fails with (ModuleNotFoundError: No module named 'idf_component_manager') message
So I just uninstalled and reinstalled VScode, uninstalled Platformio, deleted all existing projects and the .platformio directory in users/xxxx/. Next I restarted and reinstalled Platformio.
Now when I try and create a new project (espidf) it fails with the following log.
PIO Core Call Error: "The current working directory D:\Documents\PlatformIO\Projects\EspIdfTestProject will be used for the project.
The next files/directories have been created in D:\Documents\PlatformIO\Projects\EspIdfTestProject
Resolving lolin_d32_pro dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
Error: Processing lolin_d32_pro (platform: espressif32; board: lolin_d32_pro; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin_d32_pro.html
PLATFORM: Espressif 32 (5.3.0) > WEMOS LOLIN D32 PRO
 - framework-espidf @ 3.40403.0 (4.4.3)
 - tool-cmake @ 3.16.4
 - tool-esptoolpy @ 1.40400.0 (4.4.0)
 - tool-idf @ 1.0.1
 - tool-mconf @ 1.4060000.20190628 (406.0.0)
 - tool-ninja @ 1.9.0
 - toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
Installing ESP-IDF's Python dependencies
Collecting cryptography<35.0.0,>=2.1.4
 Using cached cryptography-3.4.8-cp36-abi3-win_amd64.whl (1.6 MB)
Collecting future>=0.15.2
 Using cached future-0.18.3-py3-none-any.whl
Collecting kconfiglib==13.7.1
 Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
Collecting idf-component-manager~=1.0
 Using cached idf_component_manager-1.2.1-py3-none-any.whl (116 kB)
Collecting cffi>=1.12
 Using cached cffi-1.15.1-cp39-cp39-win_amd64.whl (179 kB)
Collecting pyyaml>5.2
 Using cached PyYAML-6.0-cp39-cp39-win_amd64.whl (151 kB)
Collecting cachecontrol[filecache]>0.12.6
 Using cached CacheControl-0.12.11-py2.py3-none-any.whl (21 kB)
Collecting tqdm<5
 Using cached tqdm-4.64.1-py2.py3-none-any.whl (78 kB)
Collecting colorama
 Using cached colorama-0.4.6-py2.py3-none-any.whl (25 kB)
Collecting requests-toolbelt
 Using cached requests_toolbelt-0.10.1-py2.py3-none-any.whl (54 kB)
Collecting requests<3
 Using cached requests-2.28.2-py3-none-any.whl (62 kB)
Collecting schema
 Using cached schema-0.7.5-py2.py3-none-any.whl (17 kB)
Collecting contextlib2>0.6.0
 Using cached contextlib2-21.6.0-py2.py3-none-any.whl (13 kB)
Collecting requests-file
 Using cached requests_file-1.5.1-py2.py3-none-any.whl (3.7 kB)
Collecting packaging
 Using cached packaging-23.0-py3-none-any.whl (42 kB)
Collecting click
 Using cached click-8.1.3-py3-none-any.whl (96 kB)
Collecting six
 Using cached six-1.16.0-py2.py3-none-any.whl (11 kB)
Collecting msgpack>=0.5.2
 Using cached msgpack-1.0.4-cp39-cp39-win_amd64.whl (62 kB)
Collecting lockfile>=0.9
 Using cached lockfile-0.12.2-py2.py3-none-any.whl (13 kB)
Collecting pycparser
 Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Collecting charset-normalizer<4,>=2
 Using cached charset_normalizer-3.0.1-cp39-cp39-win_amd64.whl (96 kB)
Collecting urllib3<1.27,>=1.21.1
 Using cached urllib3-1.26.14-py2.py3-none-any.whl (140 kB)
Collecting idna<4,>=2.5
 Using cached idna-3.4-py3-none-any.whl (61 kB)
Collecting certifi>=2017.4.17
 Using cached certifi-2022.12.7-py3-none-any.whl (155 kB)
Installing collected packages: msgpack, lockfile, charset-normalizer, urllib3, six, pyyaml, pycparser, packaging, kconfiglib, idna, future, contextlib2, colorama, certifi, tqdm, schema, requests, click, cffi, requests-toolbelt, requests-file, cryptography, cachecontrol, idf-component-manager
 Attempting uninstall: msgpack
 Found existing installation: msgpack 1.0.4
 Uninstalling msgpack-1.0.4:
 Successfully uninstalled msgpack-1.0.4
 Attempting uninstall: lockfile
 Found existing installation: lockfile 0.12.2
 Uninstalling lockfile-0.12.2:
 Successfully uninstalled lockfile-0.12.2
 Attempting uninstall: charset-normalizer
 Found existing installation: charset-normalizer 3.0.1
 Uninstalling charset-normalizer-3.0.1:
 Successfully uninstalled charset-normalizer-3.0.1
ERROR: Could not install packages due to an OSError: [WinError 5] Access is denied: 'C:\\Users\\deckc\\.platformio\\penv\\Lib\\site-packages\\~=arset_normalizer\\md.cp39-win_amd64.pyd'
Check the permissions.
*** Error 1
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.39.0.windows.2")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/deckc/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/deckc/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/deckc/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Users/deckc/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Users/deckc/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
-- Configuring incomplete, errors occurred!
See also "D:/Documents/PlatformIO/Projects/EspIdfTestProject/.pio/build/lolin_d32_pro/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any of the parent directories): .git
CMake Error at C:/Users/deckc/.platformio/packages/framework-espidf/tools/cmake/build.cmake:452 (message):
 C:\Users\deckc\.platformio\penv\Scripts\python.exe: Error while finding
 module specification for 'idf_component_manager.prepare_components'
 C:/Users/deckc/.platformio/packages/framework-espidf/tools/cmake/project.cmake:384 (idf_build_process)
 CMakeLists.txt:3 (project)
========================= [FAILED] Took 10.56 seconds ========================="
Can somebody help me out please I have done several restarts etc.
I have the same problem trying to build an existing project. The error messages in the log are basically the same. I also reinstalled PlatformIO, deleted the .platformio directory and tried to build it with only the platformIO core without VS Code, but nothing helps.
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32thing_plus.html
PLATFORM: Espressif 32 (5.2.0) > SparkFun ESP32 Thing Plus
HARDWARE: ESP32 240MHz, 320KB RAM, 16MB Flash
 - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
 - framework-espidf @ 3.40402.0 (4.4.2)
 - tool-esptoolpy @ 1.40201.0 (4.2.1)
 - tool-idf @ 1.0.1
  Using cached cffi-1.15.1-cp311-cp311-win_amd64.whl (179 kB)
Collecting schema
Collecting six
Collecting tqdm<5
Collecting colorama
  Using cached PyYAML-6.0-cp311-cp311-win_amd64.whl (143 kB)
Collecting click
  Using cached msgpack-1.0.4-cp311-cp311-win_amd64.whl
  Using cached charset_normalizer-3.0.1-cp311-cp311-win_amd64.whl (96 kB)
ERROR: Could not install packages due to an OSError: [WinError 5] Zugriff verweigert: 'C:\\Users\\TenEquip\\.platformio\\penv\\Lib\\site-packages\\~.arset_normalizer\\md.cp311-win_amd64.pyd'
*** Error 1
Warning! Arduino framework as an ESP-IDF component doesn't handle the `variant` field! The default `esp32` variant will be used.
-- Found Git: C:/Users/TenEquip/AppData/Local/Programs/Git/cmd/git.exe (found version "2.30.0.windows.2")
-- Found assembler: C:/Users/TenEquip/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/TenEquip/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/TenEquip/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe -- works
-- Check for working CXX compiler: C:/Users/TenEquip/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Users/TenEquip/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++.exe -- works
See also "C:/Users/TenEquip/Desktop/TenEquip_ESP32/.pio/build/esp32/CMakeFiles/CMakeOutput.log".
CMake Error at C:/Users/TenEquip/.platformio/packages/framework-espidf/tools/cmake/build.cmake:454 (message):
  C:\Users\TenEquip\.platformio\penv\Scripts\python.exe: Error while finding
  C:/Users/TenEquip/.platformio/packages/framework-espidf/tools/cmake/project.cmake:384 (idf_build_process)
Any antivirus active?
I deactivated the windows real-time virus protection and i do not have any other antivirus installed. Still the same error.
I tried to build it again with platform = espressif32@5.1.0 in the platformio.ini file and that worked.
And explicitly switching back to 5.2.0 fails? ~~If yes, issue to https://github.com/platformio/platform-espressif32/issues.~~ Maybe this is
Thank you, I uninstalled Platformio and reinstalled with Kaspersky antivirus deactivated, I then created a project successfully with the antivirus still off. Once the first project was done I reactivated the antivirus and could create further projects without problems.
switching back to 5.2.0 results in the same error. I will try to investigate a bit further in the coming days. For now I can live with version 5.1.0 as well. Anyway, thank you for your help!
I maintain the platformio espressif32 fork for project Tasmota.
Back ported the pip install dependencies way from release 6.0.0 (IDF 5.0) to IDF 4.4.3. Since I do not use Windows idk if this solves.
You can try with
platform = https://github.com/Jason2866/platform-espressif32.git
With the Tasmota fork it works as well, thank you!
Also building with release 6.0.0 works.
Release 5.2.0 and 5.3.0 do not work.
Using the Tasmota fork worked for me, thanks so much jason, you’re a real life saver!
Any idea what causes the issue initially, and how this solves it?
I am running Ubuntu 25 with Python 3.13 installed. I noticed that some required packages were missing, and I encountered the following errors:
  • fatal error: Python.h: No such file or directory while building the native extension for ruamel.yaml.clibz
  • ModuleNotFoundError: No module named 'idf_component_manager' (maybe due to the first error)
With the assistance of GPT, I installed the following packages:
sudo apt install build-essential cmake git pkg-config \
python3-dev python3-venv python3-pip python3.13-dev \
libssl-dev libffi-dev zlib1g-dev libbz2-dev liblzma-dev \
python3-setuptools python3-wheel
Done!
