I am having a problem with being able to debug the marlin-firmware for my printer. Essentially, what I want to do is to create an .elf-file from VSCode, which I then use to debug the STM32F407-Controller by STM32CubeIDE. In STM32CubeIDE, I currently can not debug because variables are getting filled with values, breakpoints are just omitted etc… I suspect the .elf-file to be the problem because I can confirm that the firmware of the printer works (confirmed by performing actions via UART and reading answers form UART).
My configuration looks as follows:
# MKS Robin Nano V3 with USB Flash Drive Support and Shared Media
# Currently, using a STM32duino fork, until USB Host and USB Device MSC get merged
[env:mks_robin_nano_v3_usb_flash_drive_msc]
build_type = debug
debug_build_flags = -O0 -ggdb3 -g3 -DUSBCON -DUSE_USBHOST_HS -DUSBD_IRQ_PRIO=5 -DUSBD_IRQ_SUBPRIO=6 -DUSE_USB_HS_IN_FS -DUSBD_USE_CDC_MSC
extends = env:mks_robin_nano_v3
platform_packages = framework-arduinoststm32@https://github.com/rhapsodyv/Arduino_Core_STM32/archive/usb-host-msc-cdc-msc.zip
build_unflags = ${common_stm32.build_unflags} -DUSBD_USE_CDC
build_flags = ${stm32_flash_drive.build_flags}
-DUSBCON
-DUSE_USBHOST_HS
-DUSBD_IRQ_PRIO=5
-DUSE_USB_HS_IN_FS
-DUSBD_USE_CDC_MSC
Does anyone have an idea how I can actually produce entirely unoptimized code to perform debugging?
