Do any of you folks know where I can find the source code for how PlatformIO handles the uploadfs target?
As a learning exercise I wanted to create a new target “buildfs” that omits the upload part of building a SPIFFS file system.
Please open an issue here and we will implement it Issues · platformio/platform-espressif8266 · GitHub
Is the code for -t uploadfs
available online to be studied ? I was hoping to learn from this in order to create my own custom target in extra_script
Sure!
its not as simple as I thought!! i thought I could get away with drag and dropping that code into my extra_script.py
I’ll make do with a fake upload to build my SPIFFS.bin for now
Too hopeful … extra_script.py
Import("env")
from os.path import join
from SCons.Script import AlwaysBuild
def buildFS(source, target, env):
target_firm = env.DataToBin(
join("$BUILD_DIR", "spiffs"), "$PROJECTDATA_DIR")
AlwaysBuild(target_firm)
env.AddPreAction("upload", buildFS)
Resolved in the latest release
Documentation doesn’t reflect that this is now available. Neither Redirecting... nor anywhere else I could find helps you find this “buildfs” option
New docs has not been released yet. See the latest version of docs:
If I do “pip install platformio” and I get the version that supports buildfs, I kinda consider that to be “released”
This is a specific issue. PIO Docs is linked with PIO Core repository. As result, it updates when a new release is out. Nevertheless, we have moved docs to separate repository
PIO Docs will live with own life after PIO Core 3.2 release.
