Cppcheck - how to exclude Includes?
I have a project with platform files (like CMSIS, etc) being part of the project - for various reasons!
Those files are included as instructed by build_flags = -I src/CMSIS.
When I use cppcheck with misra I am getting hundreds of warnings originating from the CMSIS and others that are not user code.
When I run pio check -v, I can see all the Includes being listed. I don’t want any of them - per the manual:
How can I remove arbitrary or all the includes? I can only add new ones using check_flags. It would be best if that check_flags = cppcheck: --I xxxxx command was replacing the Includes, instead of adding to them.
Per Cppcheck — PlatformIO latest documentation and Cppcheck: how to skip a directory of third party header files? - Stack Overflow, could you use something like
check_flags =
  cppcheck: --suppress=*:src/CMSIS/*
I tried a few different versions of it, but I cannot make it work. This also probably would have to be an absolute path judging by the rest of the arguments cppcheck.exe is getting.
check_flags =
  cppcheck:--addon=misra.json --std=c99 --language=c --suppress=*:C:\Users\dzidm\Repos\firmware\src\CMSIS\core_cm3.h:*
I think suppression may not work with misra plugin - based on issues online…
Besides, Cppcheck would run much much faster if it didn’t have go through all the includes.
Indeed, --suppress=*:*/src/CMSIS/* should be used as the flag so that the path in front of it doesn’t matter.
This does work, I have personally tested this with the GitHub - maxgerhardt/pio-exclude-cppcheck project.
Without the suppress, found defects:
Component     HIGH    MEDIUM    LOW
src            0        0        6
src\CMSIS      0        0      1304
src\Device     0        0       40
Total          0        0      1350
With the flag:
src            0        0        6
src\Device     0        0       40
Total          0        0       46
Since I don’t see an option in PlatformIO to do this, you would have to file a feature request at Issues · platformio/platformio-core · GitHub.
Ah - that extra * in front did the job. Thank you for the example. :heart:
Any idea how would you suppress multiple directories? - src/CMSIS and src/Device from your example.
I have created a feature request as suggested:
Adding multiple --suppress flags is allowed.
check_flags =
  cppcheck:--addon=misra.json --std=c99 --language=c  --suppress=*:*/src/CMSIS/* --suppress=*:*/src/Device/*
gives only
src            0        0        6
Total          0        0        6
And of course that worked!
Interesting that --addon=misra gives less results than --addon=misra.json:
Checking genericSTM32F103C8 > cppcheck (platform: ststm32; board: genericSTM32F103C8)
src\main.c:4: [low:style] misra violation (use --rule-texts=<file> to get proper output) [misra-c2012-8.2]
src\main.c:8: [low:style] misra violation (use --rule-texts=<file> to get proper output) [misra-c2012-10.1]
src\main.c:5: [low:style] misra violation (use --rule-texts=<file> to get proper output) [misra-c2012-11.4]
src\main.c:6: [low:style] misra violation (use --rule-texts=<file> to get proper output) [misra-c2012-11.4]
============================================================================================================== [PASSED] Took 4.27 seconds ==============================================================================================================
src            0        0        4
Total          0        0        4
Environment         Tool      Status    Duration
genericSTM32F103C8  cppcheck  PASSED    00:00:04.267
Perhaps related to:
https://sourceforge.net/p/cppcheck/discussion/development/thread/0e4ddebe12/
