Cpp file in src not found
I am using googtest to test a project
The project contains a number of standard H and cpp files in the src directory
When I run the tests the compiler fails with an undefined reference - it looks like the compiler cannot load the cpp file.
When I add a the following to the unit test it compiles successfully
#include "dry_enum.h"
#include "dry_enum.cpp"
The normal build of a arduino target works fine.
Why is this happening?
Why do i need to add the specific include of the cpp file?
thanks
As documented
https://docs.platformio.org/en/latest/projectconf/sections/env/options/test/test_build_src.html
you should refactor to-be-unit-tested logic into its own library in lib/, then the unit tests will automatically find it. Not so if they’re in src/, by default.
