Hey guys, I am facing an issue that I couldn’t turn arround, I would like to ask your help.
I am trying to add an assembly code mixed to my Cpp code, but the issue “arm-none-eabi-as: unrecognized option `-x’” always happen. what could I do to fix this? I am following the mbed page Assembly Language - Cookbook | Mbed and simplifying the code example.
AREA asm_func, CODE, READONLY
@ Export my_asm function location so that C compiler can find it and link
EXPORT my_asm
my_asm:
CMP R0, #0
ITE EQ
MOVEQ R0, #1
MOVNE R0, #0
BX LR
END
This is my assembly code. But I guess this is not the problem.
Hi @valeros,
Maybe that is a different assembly but the main issue in this case seems to be the compilation command that is using an unrecognized flag/option.
I’ve just compiled a simple project with .S file without any error. -x option is needed by the arm-none-eabi-gcc to build assembly files, so the arm-none-eabi-as shouldn’t be called directly.
Could you please share your project to reproduce this issue?
I had the same issue. Problem was in the file extension “s” (originally I copied filename “demo_asm.s” from somewhere) instead of “S”.
This is my “demo_asm.S” which can be built sucessfully
@ File demo_asm.s
.syntax unified
.cpu cortex-m4
.section .text
.global norm_sq_asm
norm_sq_asm:
@ Input array address: R0
@ Number of elements: R1
MOVS R2, R0 @ move the address in R0 to R2
MOVS R0, #0 @ initialize the result
sum_loop:
LDRSH R3, [R2], #0x2 @ load int16_t value pointed to by R2 into R3, then increment
MLA R0, R3, R3, R0 @ sq & accum in one step (faster)
SUBS R1, #1 @ R1 = R1 - 1, decrement the count
BNE sum_loop @ branch if value not zero
BX LR @ return R0
