CP210x driver does not work with ESP32 on Windows 10
Yeah you are right, forgot to disclose that I bought it on Aliexpress, and contacting them for these kind of problems seems pointless.
Also, I am using an USB-hub, since my laptop has only USB-C ports. This morning, I connected the ESP32 through the hub, and the device was working! Couple hours later, tried again, same error code 10. However, I just tried it with an USB-C to micro cable, et voila, ESP32 functions normally. So the hub seems to be the issue.
The installed driver:
Device events:
22-May-20 16:09:06 - Device install requested:
  • Device USB\VID_10C4&PID_EA60\0001 requires further installation.
22-May-20 16:09:06 - Driver service added (silabser)
  • Driver Management has concluded the process to add Service silabser for Device Instance ID USB\VID_10C4&PID_EA60\0001 with the following status: 0.
22-May-20 16:09:06 - Device installed (silabser.inf_amd64_dfdf591955e10cae)
  • Driver Management concluded the process to install driver silabser.inf_amd64_dfdf591955e10cae for Device Instance ID USB\VID_10C4&PID_EA60\0001 with the following status: 0x0.
