@mbarney and @maxgerhardt thanks for the discussion.
I had a similar problem of “PIO Home” tools not working with Windows10. Not been working for 6months. The local build was working.
I’ve followed a lot of the suggestions, completely reinstalling VSC.
Finally I manually deleted .platformio
which really stopped everything.
After following manual install from cmd, and then on code directories executing
pio test
they downloaded the tools (amaazzzing) and rebuilt it.
Switching back to VSC it all worked, and PIO Home now comes up.
many thanks for sharing.
hi ,guys.
also try Uninstalled PIO IDE from VSCode.
Uninstalled Python.
Reboot.
Installed latest Python
but open http://127.0.0.1:8008/ still ERR_CONNECTION_REFUSED
PS D:\esp8266Project\cube-dashboard> pio home
___I_
/\-_--\ PlatformIO Home
/ \_-__\
|[]| [] | http://127.0.0.1:8008/
|__|____|________________________
Open PlatformIO Home in your browser by this URL => http://127.0.0.1:8008/
PlatformIO Home server is already started in another process.
Error: Could not start PIO Home server: Error: timeout at c:\Users\void\.vscode\extensions\platformio.platformio-ide-2.3.3\node_modules\platformio-node-helpers\dist\index.js:1:5946...
I manually delete the .platformio folder. reinstall PIO IDE, and it still not work
please help me ,thanks
Solved by setting the port to >10000
I’m having the same issue on a new install of PIO. Can you please direct me on how to change the port settings for the server?
In my case, I solved the problem by installing PlatformIO via pip install platformio and unchecking the options “Platformio-ide: Use Builtin PIOCore” and “Platformio-ide: Use Builtin Python” in Preferences >> Settings >> Platformio-ide.
