I couldn’t initalize a new project on PlatformIO. The problem description is below.
I have the latest versions:
VS Code: 1.49.1
PlatformIO: 2.1.0
The platforms are also updated.
Please help!
PIO Core Call Error:
“The current working directory C:UsersschwarztDocumentsPlatformIOProjectskd will be used for the project.
The next files/directories have been created in C:UsersschwarztDocumentsPlatformIOProjectskd
Error: Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 (2.0.0) > Espressif ESP32 Dev Module
- framework-espidf 3.40100.200827 (4.1.0)
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80200.200827 (8.2.0)
Reading CMake configuration…
-- Could NOT find Git (missing: GIT_EXECUTABLE)
-- The C compiler identification is GNU 8.2.0
-- The CXX compiler identification is GNU 8.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/schwarzt/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/schwarzt/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/schwarzt/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc.exe – works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Users/schwarzt/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Users/schwarzt/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-g++.exe – works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Project is not inside a git repository, or git repository has no commits; will not use ‘git describe’ to determine PROJECT_VER.
-- Project version: 1
-- Building ESP-IDF components for target esp32
-- Checking Python dependencies…
-- Configuring incomplete, errors occurred!
See also “C:/Users/schwarzt/Documents/PlatformIO/Projects/kd/.pio/build/esp32dev/CMakeFiles/CMakeOutput.log”.
CMake Warning at C:/Users/schwarzt/.platformio/packages/framework-espidf/tools/cmake/git_submodules.cmake:4 (message):
Git executable was not found. Git submodule checks will not be executed.
If you have any build issues at all, start by adding git executable to the
PATH and rerun cmake to not see this warning again.
C:/Users/schwarzt/.platformio/packages/framework-espidf/tools/cmake/idf.cmake:39 (include)
C:/Users/schwarzt/.platformio/packages/framework-espidf/tools/cmake/project.cmake:7 (include)
CMakeLists.txt:2 (include)
CMake Error at C:/Users/schwarzt/.platformio/packages/framework-espidf/tools/cmake/build.cmake:271 (message):
Some Python dependencies must be installed. Check above message for
details.
C:/Users/schwarzt/.platformio/packages/framework-espidf/tools/cmake/build.cmake:397 (__build_check_python)
C:/Users/schwarzt/.platformio/packages/framework-espidf/tools/cmake/project.cmake:396 (idf_build_process)
CMakeLists.txt:3 (project)
========================= [FAILED] Took 10.81 seconds ========================="
