I’m using VS Code with 3.1.1 release of PlatformIO IDE. Here are my settings:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
monitor_rts = 0
monitor_dtr = 0
build_unflags = -std=gnu++11
build_flags = -std=gnu++2a
knolleary/PubSubClient@^2.8
mikalhart/Streaming@^1.0.0
The test program:
#include <Streaming.h>
delay(1000);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
delay(500);
Serial << "blah\n";
Serial.flush();
Serial monitor displays good data when I start it before rebooting ESP32 board. Stop/Start Monitoring sequence produces corrupt data most of the time and occasionally freezes the program on ESP32 board. Here is an example of “normal” corrupted data followed by a case, which froze the program on ESP32:
---- Closed the serial port /dev/ttyACM0 ----
---- Opened the serial port /dev/ttyACM0 ----
�'� #��'�`#��'� b�
## $$$$$$d$$$d$$$d$$$$l$$$d$$$$$$$$l$$$d$$$$$$$$$$$$$$$$l$$$$$$$$l$$$$l$$$d$$$$l$$$d$$$$l$$$l$$$$$$$$l$$$$$$$$d$$$$$$$$l$$$d$$
Is there a solution to this problem? I’m testing a different device without convenient access to reboot or power cycling.
But no such issue exists when using
delay(1000);
delay(500);
Serial.print("blah\n");
Serial.flush();
? If yes, it may be a problem with the Streaming.h
library.
No. That version behaves the same.
With these options deleted it’s still broken?
And also with just
No change. I will try on a different OS/PC later today.
On some Linux distributions, certain installed programmes like brltty or modem manager can also interfere with serial ports. Make sure they’re removed (some come auto-installed with the distribution).
Yes. I did reinstall udev.rules and removed modem manager, which wasn’t there, but brltty was:
paul@desktop:~$ curl -fsSL https://raw.githubusercontent.com/platformio/platformio-core/develop/platformio/assets/system/99-platformio-udev.rules | sudo tee /etc/udev/rules.d/99-platformio-udev.rules
paul@desktop:~$ sudo service udev restart
paul@desktop:~$ sudo apt purge modemmanager
paul@desktop:~$ sudo apt purge brltty
Unfortunately, no improvement.
I tested on Raspberry Pi with the most current OS and fresh installation of VSCode and PlatformIO. Behavior is essentially the same, except of a single instance of a corrupt stream turning into a valid one.
I also noticed that my Ubuntu setup has two serial monitors. I have VSCode extension for Arduino installed there, but disabled for these tests. Here is the PlatformIO being used:
Here is the remnant of Arduino being used:
Again, the behavior is the same. There is no Arduino extension for VSCode on Raspberry Pi.
I went for something completely different and repeated this test with Seeeduino Xiao SAMD. No problems at all with starting and stopping serial monitor, both with PlatformIO and Arduino. I will test a few other ESP32 boards. Perhaps the serial to USB chip on DOIT ESP32 DEV KIT v1 board, i.e. CH9201X, is causing the problem. I selected this chip, because it is supposed to automatically go to the low power state when USB is not being used.
I tested a few different ESP32 boards with QinHeng Electronics CH340 serial to USB chip. No problems with corrupted data. It seems that behavior of CH9201X (1a86:55d4 QinHeng Electronics USB Single Serial) is the source of this problem.
