Correct board for ESP32-WROVER-KIT?
What is the correct board to choose when working with the ESP-WROVER-KIT (Overview | Espressif Systems)?
Thanks!
B
Espressif ESP32 Dev Module (esp32dev) should work fine.
Hi Butch,
I’m having trouble. I believe that the /dev/ttyUSB0 is for the JTAG, and will not work with the USB port. That is /dev/ttyUSB1. To remedy this, add
upload_port = /dev/ttyUSB1
to the platformio.ini file, under the heading esp32dev.
At this point, code appears to flash the device, but, I can’t get the serial monitor to report what is being written to the serial port. So, something else is still the matter.
Help would be welcome.
Thanks,
[env:esp-wrover-kit]
board = esp-wrover-kit
