To transfer the project to you woudn’t be much of a problem but the least you need I think is the Encoder class.
in main you need:
#include "myEncoder.h"
myEncoder roboEncoder(50.0, 66.5, 12, {4, 5}, {35, 34});
roboEncoder.setup();
myEncoder.h:
#ifndef myEncoder_h__
#define myEncoder_h__
#define mvAvg_length 5
struct myEncoder_pins
// myEncoder has EncA and EncB pins
uint8_t encA;
uint8_t encB;
// All the data needed by interrupts is consolidated into this ugly struct
// to facilitate assembly language optimizing of the speed critical update.
// The assembly code uses auto-incrementing addressing modes, so the struct
// must remain in exactly this order.
typedef struct
volatile uint32_t *pin1_register;
volatile uint32_t *pin2_register;
uint32_t pin1_bitmask;
uint32_t pin2_bitmask;
uint8_t state;
int32_t position;
} Encoder_internal_state_t;
struct myEncoder_struct{
//sensor pin (can be any for the esp32 cause function is handled by abstraction matrix)
myEncoder_pins enc;
// counts per revolution -> rising and falling edge is measured
unsigned long cntPerRev;
// amount of counts since start
volatile long counter;
// amount of counts since last tie it was updated
volatile long lastCounter;
// radius of the wheel
double radius;
// wheel rounds per second (moving average)
double mvAvgOmega[mvAvg_length];
double omega;
// tangential linearvel of one wheel
double vel;
// total distance travelled
volatile double distance;
//Encoder libenc(myEncoder_pins enc.encA, myEncoder_pins enc.encB);
class myEncoder{
public:
* Configure PWM parameter
* @param[in] rate rate on which counts are updated -> higher rate leads to larger errors on small speeds
* @param[in] wheelDiameter Diameter of wheel in mm
* @param[in] countsPerRevolution counts per revolution -> rising and falling edge is measured
* @param[in] enc1pin sensor pin (can be any for the esp32 because function is handled by hardware abstraction matrix)
* @param[in] enc2pin sensor pin (can be any for the esp32 because function is handled by hardware abstraction matrix)
myEncoder(double rate, double wheelDiameter, unsigned long countsPerRevolution, myEncoder_pins enc1, myEncoder_pins enc2);
//Encoder myEnc(myEncoder_pins enc1, myEncoder_pins enc2);
* Destructor does not do anything
~myEncoder();
// void IRAM_ATTR ISR_enc1();
// void IRAM_ATTR ISR_enc2();
// void IRAM_ATTR ISR_enc3();
// void IRAM_ATTR ISR_enc4();
// struct to store date of encoderLeft
myEncoder_struct encoderLeft;
// struct to store internal libencoderLeft values
Encoder_internal_state_t libencoderLeft;
// struct to store date of encoderRight
myEncoder_struct encoderRight;
// struct to store internal libencoderRight values
Encoder_internal_state_t libencoderRight;
* attatch rising and falling edge interrupts to pins
void setup();
* update counter, omega, velocity and distance of both encoder structs
void myupdate();
void myupdates();
* This encoder cant detect rotation direction by itself -> needs to be supplied
* @param[in] encoderNum encoder number 1 or 2
//void setCntDir(unsigned int encoderNum);
* print total driven distance to SerialPort
void printDistance();
* update the counter variable
inline int32_t readRIGHT();
inline int32_t readLEFT();
* update the counter variable and reset the internal interrupt counter
int32_t readAndResetRIGHT();
int32_t readAndResetLEFT();
* write a certain variable p into the internal interrupt counter
* @param[in] p variable that is written into the internal interrupt counter
inline void writeRIGHT(int32_t p);
inline void writeLEFT(int32_t p);
//static void update(Encoder_internal_state_t *arg);
private:
double updateRate;
unsigned long previousMillis = 0;
* calculate omega, velocity and distance of both encoder structs
* uses elapsed time, measured counters and wheel radius
* @param[in] encoder strcut of the encoders which shall be updated
* @param[in] dT elapsed time since function was called the last time
void calculateValues(myEncoder_struct &encoder, double dT);
myEncoder.cpp:
#define ENCODER_ARGLIST_SIZE 4+1
static Encoder_internal_state_t *interruptArgs[ENCODER_ARGLIST_SIZE];
myEncoder::myEncoder(double rate, double wheelDiameter, unsigned long countsPerRevolution, myEncoder_pins enc1pin, myEncoder_pins enc2pin)
updateRate = rate;
encoderLeft.enc.encA = enc1pin.encA;
encoderLeft.enc.encB = enc1pin.encB;
encoderLeft.cntPerRev = countsPerRevolution;
encoderLeft.radius = ((wheelDiameter) / 2.0) / 1000.0; // diamter in mm to radius in m
encoderRight.enc.encA = enc2pin.encA;
encoderRight.enc.encB = enc2pin.encB;
encoderRight.cntPerRev = countsPerRevolution;
encoderRight.radius = ((wheelDiameter) / 2.0) / 1000.0; // diamter in mm to radius in m
myEncoder::~myEncoder(){
// interrupt service routine is volatile and can not call members of a class
// volatile long counter1;
// volatile int cntDir1 = 1;
static void IRAM_ATTR ISR_enc1()
//counter1 += cntDir1;
update(interruptArgs[1]);
// volatile long counter2;
// volatile int cntDir2 = 1;
static void IRAM_ATTR ISR_enc2()
//counter2 += cntDir2;
update(interruptArgs[2]);
// volatile long counter3;
// int cntDir3 = 1;
static void IRAM_ATTR ISR_enc3()
//counter3 += cntDir3;
update(interruptArgs[3]);
// volatile long counter4;
// int cntDir4 = 1;
static void IRAM_ATTR ISR_enc4()
//counter4 += cntDir4;
update(interruptArgs[4]);
void myEncoder::setup(){
// set pins to output
pinMode(encoderLeft.enc.encA, INPUT_PULLUP);
pinMode(encoderLeft.enc.encB, INPUT_PULLUP);
pinMode(encoderRight.enc.encA, INPUT_PULLUP);
pinMode(encoderRight.enc.encB, INPUT_PULLUP);
libencoderLeft.pin1_register = (portInputRegister(digitalPinToPort(encoderLeft.enc.encA)));
libencoderLeft.pin1_bitmask = (digitalPinToBitMask(encoderLeft.enc.encA));
libencoderLeft.pin2_register = (portInputRegister(digitalPinToPort(encoderLeft.enc.encB)));
libencoderLeft.pin2_bitmask = (digitalPinToBitMask(encoderLeft.enc.encB));
libencoderLeft.position = 0;
libencoderRight.pin1_register = (portInputRegister(digitalPinToPort(encoderRight.enc.encA)));
libencoderRight.pin1_bitmask = (digitalPinToBitMask(encoderRight.enc.encA));
libencoderRight.pin2_register = (portInputRegister(digitalPinToPort(encoderRight.enc.encB)));
libencoderRight.pin2_bitmask = (digitalPinToBitMask(encoderRight.enc.encB));
libencoderRight.position = 0;
// allow time for a passive R-C filter to charge
// through the pullup resistors, before reading
// the initial state
delayMicroseconds(2000);
uint8_t statelibencoder1 = 0;
if ((((*(libencoderLeft.pin1_register)) & (libencoderLeft.pin1_bitmask)) ? 1 : 0)) statelibencoder1 |= 1;
if ((((*(libencoderLeft.pin2_register)) & (libencoderLeft.pin2_bitmask)) ? 1 : 0)) statelibencoder1 |= 2;
libencoderLeft.state = statelibencoder1;
uint8_t statelibencoder2 = 0;
if ((((*(libencoderRight.pin1_register)) & (libencoderRight.pin1_bitmask)) ? 1 : 0)) statelibencoder1 |= 1;
if ((((*(libencoderRight.pin2_register)) & (libencoderRight.pin2_bitmask)) ? 1 : 0)) statelibencoder1 |= 2;
libencoderRight.state = statelibencoder2;
// attatch an interrupt detector to 2 pins threough the hardware abstraction matrix
interruptArgs[1] = &libencoderLeft;
attachInterrupt(encoderLeft.enc.encA, ISR_enc1, CHANGE);
interruptArgs[2] = &libencoderLeft;
attachInterrupt(encoderLeft.enc.encB, ISR_enc2, CHANGE);
interruptArgs[3] = &libencoderRight;
attachInterrupt(encoderRight.enc.encA, ISR_enc3, CHANGE);
interruptArgs[4] = &libencoderRight;
attachInterrupt(encoderRight.enc.encB, ISR_enc4, CHANGE);
encoderLeft.counter = 0;
//enclib1.write(0);
encoderRight.counter = 0;
//enclib2.write(0);
void myEncoder::myupdate(){
// measure elapsed time
double dT = (millis() - previousMillis)/1000.0;
if(dT > 1/updateRate){
// update class member counter values
encoderLeft.counter = readAndResetLEFT();
encoderRight.counter = readAndResetRIGHT();
// calculate w, v, distance
calculateValues(encoderLeft, dT);
calculateValues(encoderRight, dT);
previousMillis = millis();
void myEncoder::myupdates()
double dT = (millis() - previousMillis) / 1000.0;
if (dT > 1 / updateRate)
encoderLeft.counter = readAndResetRIGHT();
encoderRight.counter = readAndResetLEFT();
void myEncoder::calculateValues(myEncoder_struct &encoder, double dT){
// counter * angle resolution * radius
encoder.distance = encoder.counter * ( (2*3.14) / encoder.cntPerRev) * encoder.radius;
double dPhi = (encoder.counter - encoder.lastCounter) * ( (2*3.14) / encoder.cntPerRev);
// put in array and push by 1
for(int i = mvAvg_length-1; i >= 1; i--){
encoder.mvAvgOmega[i] = encoder.mvAvgOmega[i-1];
encoder.mvAvgOmega[0] = dPhi/dT;
// calculate moving avg
encoder.omega=0;
for(int i=0; i<mvAvg_length; i++){
encoder.omega += encoder.mvAvgOmega[i];
encoder.omega /= mvAvg_length;
// tangential linear velocity
encoder.vel = encoder.omega * encoder.radius;
encoder.lastCounter = encoder.counter;
// this is only usefull if you cannot determin the direction from encoders
// void myEncoder::setCntDir(unsigned int encoderNum){
// // this sensor can detect rotation direction by itself
// if(encoderNum == 1){
// if (encoderLeft.counter > 0){
// cntDir1 = 1;
// else if (encoderLeft.counter == 0)
// cntDir1 = 0;
// else
// cntDir1 = -1;
// } else {
// if (encoderRight.counter > 0)
// cntDir2 = 1;
// else if (encoderRight.counter == 0)
// cntDir2 = 0;
// else
// cntDir2 = -1;
void myEncoder::printDistance(){
Serial.print("\ndsit 1 ");
Serial.print(encoderLeft.distance);
Serial.print("\n dsit 2 ");
Serial.println(encoderRight.distance);
inline int32_t myEncoder::readRIGHT()
noInterrupts();
update(&libencoderLeft);
int32_t ret = libencoderLeft.position;
interrupts();
return ret;
inline int32_t myEncoder::readLEFT()
noInterrupts();
update(&libencoderRight);
int32_t ret = libencoderRight.position;
interrupts();
return ret;
int32_t myEncoder::readAndResetRIGHT()
// noInterrupts();
// interrupts();
return ret;
int32_t myEncoder::readAndResetLEFT()
// noInterrupts();
// interrupts();
return ret;
inline void myEncoder::writeRIGHT(int32_t p){
noInterrupts();
libencoderLeft.position = p;
interrupts();
inline void myEncoder::writeLEFT(int32_t p)
noInterrupts();
libencoderRight.position = p;
interrupts();
// _______ _______
// Pin1 ______| |_______| |______ Pin1
// negative <--- _______ _______ __ --> positive
// Pin2 __| |_______| |_______| Pin2
// new new old old
// pin2 pin1 pin2 pin1 Result
// 0 0 0 0 no movement
// 0 0 0 1 +1
// 0 0 1 0 -1
// 0 0 1 1 +2 (assume pin1 edges only)
// 0 1 0 0 -1
// 0 1 0 1 no movement
// 0 1 1 0 -2 (assume pin1 edges only)
// 0 1 1 1 +1
// 1 0 0 0 +1
// 1 0 0 1 -2 (assume pin1 edges only)
// 1 0 1 0 no movement
// 1 0 1 1 -1
// 1 1 0 0 +2 (assume pin1 edges only)
// 1 1 0 1 -1
// 1 1 1 0 +1
// 1 1 1 1 no movement
uint8_t p1val = (((*(arg->pin1_register)) & (arg->pin1_bitmask)) ? 1 : 0);
uint8_t p2val = (((*(arg->pin2_register)) & (arg->pin2_bitmask)) ? 1 : 0);
uint8_t state = arg->state & 3;
if (p1val)
state |= 4;
if (p2val)
state |= 8;
arg->state = (state >> 2);
switch (state)
case 1: case 7: case 8: case 14:
arg->position++;
//Serial.printf("position = %d\n", arg->position);
return;
case 2: case 4: case 11: case 13:
arg->position--;
return;
case 3: case 12:
arg->position += 2;
return;
case 6: case 9:
arg->position -= 2;
return;
Sorry for the mess it is still under construction :).
