I am trying to install platformIO CLI following the guide:
https://docs.platformio.org/en/stable/core/installation/methods/installer-script.html
using
python3 -c “$(curl -fsSL https://raw.githubusercontent.com/platformio/platformio/master/scripts/get-platformio.py)”
It seems that the link is broken as I get an error 404: Not Found.
Can somebody else confirm this? Is it going to be fixed or should I find another way to install?
Hi @kl1
It seems indeed that the script has been moved to another repo, could you try theses two commands instead:
curl -fsSL -o get-platformio.py https://raw.githubusercontent.com/platformio/platformio-core-installer/master/get-platformio.py
python3 get-platformio.py
EDIT: The new command in documentation has not been released yet, here you will find the latest documentation with the correct command.
What is your use case? Why do you need the Installer Script?
