Hi
I am a first time user of platformIO and so far I like it.
I have install pio and its cli tools and i am ably to build and burn my project.
I am using nvim and ran into a bit of an issue with my lsp (i think)
As you can see it is not finding stdlib.h …
I did however run pio run -t compiledb
ps I hope I am posting this in the correct category
stdlib.h is included in the compiler. If your LSP ignores the compiler path given to it, you’ll likely have to have to activate the COMPILATIONDB_INCLUDE_TOOLCHAIN feature so that the compiler’s include path will also be in the generated compile_commands.json:
