Constant crashes with Arduino Giga
I am trying to use LVGL with the Arduino GIGA R1 WiFi Board (with the GIGA Display Shield) but, especially after using the WiFi library, I keep getting crashes seemingly at random.
After debugging for some time with a simple sketch, I’ve tried to upload it to the board using the Arduino IDE and apparently everything runs fine this way.
Here’s the sketch:
#include <Arduino_GigaDisplayTouch.h>
#include <Arduino_GigaDisplay_GFX.h>
#include <WiFi.h>
#include <lvgl.h>
Arduino_H7_Video display(800, 480, GigaDisplayShield);
Arduino_GigaDisplayTouch touchscreen;
lv_obj_t *networkList;
bool wiFiLoopEnabled = false;
lv_obj_t *createWiFiTile(int i) {
  auto tile = lv_button_create(networkList);
  lv_obj_set_size(tile, lv_pct(100), LV_SIZE_CONTENT);
  lv_obj_set_style_bg_color(tile, lv_color_hex(0xFFFFFF), LV_PART_MAIN);
  lv_obj_set_style_text_color(tile, lv_color_hex(0x000000), LV_PART_MAIN);
  lv_obj_set_style_radius(tile, 0, LV_PART_MAIN);
  auto label = lv_label_create(tile);
  lv_label_set_text_fmt(label, "%s (Encryption: %d) (%ld dBm)", WiFi.SSID(i), WiFi.encryptionType(i), WiFi.RSSI(i));
  lv_obj_add_event_cb(
    tile,
    [](auto e) {
      auto i = (int)lv_event_get_user_data(e);
      Serial.println(WiFi.SSID(i));
    LV_EVENT_CLICKED,
    (void *)i
  return tile;
  display.begin();
  touchscreen.begin();
  auto screen = lv_screen_active();
  lv_obj_set_style_bg_color(screen, lv_color_hex(0x003A57), LV_PART_MAIN);
  lv_obj_set_flex_flow(screen, LV_FLEX_FLOW_COLUMN);
  lv_obj_set_flex_align(screen, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_START);
  auto refreshBtn = lv_button_create(screen);
  lv_obj_add_flag(refreshBtn, LV_OBJ_FLAG_CHECKABLE);
  lv_obj_set_style_pad_all(refreshBtn, 16, LV_PART_MAIN);
  lv_obj_set_style_margin_all(refreshBtn, 8, LV_PART_MAIN);
    refreshBtn,
    [](auto e) {
      auto btn = (lv_obj_t *)lv_event_get_target(e);
      wiFiLoopEnabled = lv_obj_has_state(btn, LV_STATE_CHECKED);
    LV_EVENT_CLICKED,
    nullptr
  auto refreshBtnLabel = lv_label_create(refreshBtn);
  lv_label_set_text(refreshBtnLabel, LV_SYMBOL_REFRESH " Toggle scan");
  networkList = lv_list_create(screen);
  lv_obj_set_size(networkList, lv_pct(100), LV_SIZE_CONTENT);
  lv_obj_set_style_radius(networkList, 0, LV_PART_MAIN);
  lv_obj_set_style_bg_opa(networkList, 0, LV_PART_MAIN);
  lv_obj_set_style_border_side(networkList, LV_BORDER_SIDE_NONE, LV_PART_MAIN);
  lv_obj_set_style_pad_all(networkList, 0, LV_PART_MAIN);
  lv_timer_periodic_handler();
  static int time = millis();
  if (millis() - time >= 250) {
    time = millis();
    if (wiFiLoopEnabled) {
      int numNetworks = WiFi.scanNetworks();
      Serial.println(numNetworks);
      lv_obj_clean(networkList);
      for (int i = 0; i < numNetworks; i++) {
        createWiFiTile(i);
Here’s my platform.ini file:
[env:giga_r1_m7]
platform = ststm32
board = giga_r1_m7
	arduino-libraries/Arduino_GigaDisplay@^1.0.2
The sketch draws a button that toggles an infinite scan of WiFi networks: when the scan is done a button is created for each network found.
If I run the sketch with PlatformIO, after I start scanning for networks, the sketch will randomly crash between less than a second to a few seconds, but the scan still works (everything is still properly displayed).
If I run the sketch with Arduino IDE though, the sketch seems to never crash and everything works as it should.
What am I doing wrong? And why does everything seem to work when using the Arduino IDE?
Thanks
How do you see that it crashes? Is there a crash message or a backtrace of some sort?
  • What version of the mbedOS Giga boards do you have installed in the Arduino IDE? (ref).
  • What version of the LVGL library do you use in the Arduino IDE? (C:\Users\<user>\Documents\Arduino\libraries\lvgl\library.properties)
  • What version of the ST STM32 platform do you use in PlatformIO? (in “PACKAGES” when doing a “Build”)
  • What version of the lvgl library do you use in PlatformIO? (`.pio/libdeps/giga_r1_m7/lvlg/library.properties)?
When the board crashes the sketch just freezes, the onboard LED starts flashing red and I have to manually reset the board to upload something else.
In the Arduino IDE I am using:
  • Arduino Mbed OS Giga Boards v4.2.1
  • LVGL v9.2.2
While in PlatformIO I am using:
  • framework-arduino-mbed v4.2.1
  • LVGL v9.2.2
Any updates on this?
I’ve also tried to compile the sketch from Linux and I get the same issues (everything working fine with Arduino IDE and the board crashes with PlatformIO)
