I imported an arduino project. I can build it flawlessly, but uploading fails. The baudrate is set to 460800 (that worked under Arduiono.app). But uunder pio that obviously fails:
|-- Adafruit_VL53L0X @ 1.2.4
Retrieving maximum program size .pio/build/denky32/firmware.elf
Checking size .pio/build/denky32/firmware.elf
RAM: [= ] 7.6% (used 24920 bytes from 327680 bytes)
Flash: [== ] 24.2% (used 317285 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: /dev/cu.usbserial-14110
Uploading .pio/build/denky32/firmware.bin
esptool.py v4.5.1
Serial port /dev/cu.usbserial-14110
Connecting...............
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: d4:8a:fc:94:1b:32
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
A fatal error occurred: Unable to verify flash chip connection (Serial data stream stopped: Possible serial noise or corruption.).
*** [upload] Error 2
==================================== [FAILED] Took 23.39 seconds ====================================
* Der Terminalprozess "platformio 'run', '--target', 'upload', '--environment', 'denky32'" wurde mit folgendem Exitcode beendet: 1.
* Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
Setting monitor_speed = 115200 in platform.ini makes it worse. It doen’t even connect:
A serial exception error occurred: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
*** [upload] Error 1
===================================== [FAILED] Took 9.99 seconds =====================================
