Hello all!
I found myself often commenting out some options in platformio.ini file.
I’m developing for esp32 and this is my ini
[platformio]
build_cache_dir = ./cache
[env:esp-wrover-kit]
check_skip_packages = yes
board = esp-wrover-kit
framework = arduino, espidf
;upload_protocol = espota
;upload_port = 192.168.10.107
upload_speed = 921600
monitor_filters = colorize, esp32_exception_decoder
board_upload.flash_size = 16MB
board_build.flash_mode = qio
board_build.partitions = ./Partitions/hshPartition_APP_3MB.csv
board_build.f_flash = 80000000L
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
-mfix-esp32-psram-cache-strategy=memw
-DCONFIG_SPIRAM_USE_MALLOC=1
-DCONFIG_MBEDTLS_DYNAMIC_BUFFER=1
-DCONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=1
-DCONFIG_SPIRAM_CACHE_WORKAROUND=1
-DCORE_DEBUG_LEVEL=0
-std=gnu++17
build_unflags =
-std=gnu++11
;upload_flags =
;--auth=admin_test_password
As you can see there are commented out lines like these
upload_flags =
If my esp crashes and is in a boot loop, I have to comment the remote upload things out so I can upload it via USB. But most of the time I’m uploading with IP address.
Is there a way to create a flag which would toggle these options in/out so I don’t have to comment it every time i want to upload my sketch via usb?
I’m thinking about some preprocessor macro or define in the ini file which would conditionally include these options.
Just create yet another working environment with custom options and extend the original
[env]
-DBOARD_HAS_PSRAM
-std=gnu++17
build_unflags =
-std=gnu++11
[env:esp-wrover-kit-ota]
upload_flags =
[env:esp-wrover-kit-skip-ota]
See extends — PlatformIO latest documentation
I see. will give it a try!
How to switch between these environments?
I have only one upload button at the bottom of VSCODE.
See “Project Environment Switcher”:
Yeah i have found it but now i got a bunch of compilation errors.
I also had to load all these envs one by one.
[platformio]
-DBOARD_HAS_PSRAM
-std=gnu++17
build_unflags =
-std=gnu++11
extends = env:esp-wrover-kit
upload_port = hsh.local
upload_flags =
--auth=admin_2024_04_23
Should I reconfigure the project in menuconfig for all of these environments one by one? It seems like they do not know about my menuconfig settings
Yes, I had to copy my sdkconfig of the working env to the new one. It created a new file for the new env. Thank you very much, it seems to me that it is working!
Everything became so much worse.
Now i have two sdkconfig files and if i modify one thing in menuconfig i had to redo this on the other env.
I also have to clean the project twice and things are running twice.
