Hi!
Thanks for a great product!
I have an issue where I have ESP-IDF components with their own dependencies seemingly causing problems for Platformio. The reason I think that may be the case, is that it doesn’t seem to break in running idf.py build in the same folder. ESP-IDF doesn’t seem to mind the current config.
It doesn’t compile without errors there, but that is not the problem. Abbreviated, the error is:
TypeError: 'NoneType' object is not iterable:
for cg in target_compile_groups:
It happens in espidf.py, line 614. If I monkey-patch the script to return [] if it is None, the script continues. I am not sure it works properly then, though, so there seems to be some case that isn’t covered or something.
The repository is at: GitHub - nicklasb/NMEA_Gateway
Note that the project itself has ESP-IDF-dependencies, and that this problem only occurs when I add the nmea-gateway component. If I remove it, the pio build scripts works.
I am probably doing something crazy somewhere, but I don’t get it, I have spent a lot of time trying to fix this problem now…
