I’d like to use some C++14 features in my code, and have changed the compilation flags as follows:
build_unflags = -std=gnu++11
build_flags = -std=c++14
Unfortunately one of the EspressIf libraries fails with this error message:
Compiling .pio/build/esp32dev/libf73/WebServer/detail/mimetable.cpp.o /home/xxx/.platformio/packages/framework-arduinoespressif32/libraries/FS/src/vfs_api.cpp: In member function ‘virtual void VFSFileImpl::flush()’: /home/xxx/.platformio/packages/framework-arduinoespressif32/libraries/FS/src/vfs_api.cpp:349:20: error: ‘fileno’ was not declared in this scope fsync(fileno(_f));
Has anyone found a way around this, or could suggest some options to try? Is it possible to compile partly with and partly without C++14 support?
