I’m currently writing a pull parser library, and to simplify the single tests I made an util directory with some helper classes et all.
I then proceeded to create other test_* folders with the actual tests.
However, if I include any file in the utils folders I get linking errors, which if I read the documentation right, is due to platformio treating each test_ directory as an independent project.
So my question is how do I get to compile my test helper/utils classes while sharing them among all the separate tests?
Here’s my test directory for reference
$ tree test
test
├── json
│ ├── sample1.json
│ ├── sample2.json
│ ├── sample3.json
│ ├── sample4.json
│ └── sample5.json
├── README
├── test_emptyDocument
│ └── test_emptyDocument.cc
├── test_simpleNameValue
│ └── test_simpleNameValue.cc
└── test_util
├── EventRecordHandle.cc
├── EventRecordHandle.hh
├── NameRecord.cc
├── NameRecord.hh
├── Util.cc
├── Util.hh
├── ValueRecord.cc
└── ValueRecord.hh
And the (long) error log
* Esecuzione dell'attività nella cartella MicroJson: platformio test
Verbosity level can be increased via `-v, -vv, or -vvv` option
Collected 3 tests
Processing test_util in native environment
Building...
/usr/bin/ld: /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/../../../../lib/Scrt1.o: in function `_start':
/build/glibc/src/glibc/csu/../sysdeps/x86_64/start.S:103: undefined reference to `main'
*** [.pio/build/native/program] Error 1
Building stage has failed, see errors above. Use `pio test -vvv` option to enable verbose output.
----------------------------------------------------------------------- native:test_util [ERRORED] Took 0.61 seconds -----------------------------------------------------------------------
Processing test_emptyDocument in native environment
Building...
/usr/bin/ld: .pio/build/native/test/test_emptyDocument/test_emptyDocument.o: warning: relocation against `_ZTV17EventRecordHandle' in read-only section `.text._ZN17EventRecordHandleD2Ev[_ZN17EventRecordHandleD5Ev]'
/usr/bin/ld: .pio/build/native/test/test_emptyDocument/test_emptyDocument.o: in function `emptyStructureDocument(char const*, JsonStructure)':
test_emptyDocument.cc:(.text+0x35): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_emptyDocument.cc:(.text+0x78): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_emptyDocument.cc:(.text+0x87): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_emptyDocument.cc:(.text+0x10f): undefined reference to `NameRecord::toString[abi:cxx11]()'
/usr/bin/ld: test_emptyDocument.cc:(.text+0x159): undefined reference to `ValueRecord::toString[abi:cxx11]()'
/usr/bin/ld: test_emptyDocument.cc:(.text+0x1f9): undefined reference to `NameRecord::toString[abi:cxx11]()'
/usr/bin/ld: test_emptyDocument.cc:(.text+0x243): undefined reference to `ValueRecord::toString[abi:cxx11]()'
/usr/bin/ld: .pio/build/native/test/test_emptyDocument/test_emptyDocument.o: in function `EventRecordHandle::~EventRecordHandle()':
test_emptyDocument.cc:(.text._ZN17EventRecordHandleD2Ev[_ZN17EventRecordHandleD5Ev]+0xf): undefined reference to `vtable for EventRecordHandle'
/usr/bin/ld: warning: creating DT_TEXTREL in a PIE
------------------------------------------------------------------- native:test_emptyDocument [ERRORED] Took 0.67 seconds -------------------------------------------------------------------
Processing test_simpleNameValue in native environment
Building...
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: warning: relocation against `_ZTV17EventRecordHandle' in read-only section `.text._ZN17EventRecordHandleD2Ev[_ZN17EventRecordHandleD5Ev]'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleArrayString()':
test_simpleNameValue.cc:(.text+0x26): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x77): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x86): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xf0): undefined reference to `assertNameIndex(NameRecord const&, unsigned int)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x139): undefined reference to `assertValueString(ValueRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleArrayInteger()':
test_simpleNameValue.cc:(.text+0x231): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x282): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x291): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x2fb): undefined reference to `assertNameIndex(NameRecord const&, unsigned int)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x310): undefined reference to `assertValueInteger(ValueRecord const&, int)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleArrayDouble()':
test_simpleNameValue.cc:(.text+0x3c2): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x413): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x422): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x48c): undefined reference to `assertNameIndex(NameRecord const&, unsigned int)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x4a8): undefined reference to `assertValueDouble(ValueRecord const&, double)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleArrayBool0()':
test_simpleNameValue.cc:(.text+0x55a): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x5ab): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x5ba): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x624): undefined reference to `assertNameIndex(NameRecord const&, unsigned int)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x639): undefined reference to `assertValueBool(ValueRecord const&, bool)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleArrayBool1()':
test_simpleNameValue.cc:(.text+0x6eb): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x73c): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x74b): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x7b5): undefined reference to `assertNameIndex(NameRecord const&, unsigned int)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x7ca): undefined reference to `assertValueBool(ValueRecord const&, bool)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleArrayNull()':
test_simpleNameValue.cc:(.text+0x87c): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x8cd): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x8dc): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x946): undefined reference to `assertNameIndex(NameRecord const&, unsigned int)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x956): undefined reference to `assertValueNull(ValueRecord const&)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleObjectString()':
test_simpleNameValue.cc:(.text+0xa08): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xa59): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xa68): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xb06): undefined reference to `assertNameKey(NameRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xb6d): undefined reference to `assertValueString(ValueRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleObjectInteger()':
test_simpleNameValue.cc:(.text+0xc8f): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xce0): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xcef): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xd8d): undefined reference to `assertNameKey(NameRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xdc0): undefined reference to `assertValueInteger(ValueRecord const&, int)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleObjectDouble()':
test_simpleNameValue.cc:(.text+0xe9a): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xeeb): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xefa): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xf98): undefined reference to `assertNameKey(NameRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0xfd2): undefined reference to `assertValueDouble(ValueRecord const&, double)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleObjectBool0()':
test_simpleNameValue.cc:(.text+0x10ac): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x10fd): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x110c): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x11aa): undefined reference to `assertNameKey(NameRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x11dd): undefined reference to `assertValueBool(ValueRecord const&, bool)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleObjectBool1()':
test_simpleNameValue.cc:(.text+0x12b7): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x1308): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x1317): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x13b5): undefined reference to `assertNameKey(NameRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x13e8): undefined reference to `assertValueBool(ValueRecord const&, bool)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `test_simpleObjectNull()':
test_simpleNameValue.cc:(.text+0x14c2): undefined reference to `EventRecordHandle::EventRecordHandle()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x1513): undefined reference to `parseDocumentWith(SlabParser&, EventRecordHandle&, char const*)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x1522): undefined reference to `EventRecordHandle::getEvents()'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x15c0): undefined reference to `assertNameKey(NameRecord const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
/usr/bin/ld: test_simpleNameValue.cc:(.text+0x15ee): undefined reference to `assertValueNull(ValueRecord const&)'
/usr/bin/ld: .pio/build/native/test/test_simpleNameValue/test_simpleNameValue.o: in function `EventRecordHandle::~EventRecordHandle()':
test_simpleNameValue.cc:(.text._ZN17EventRecordHandleD2Ev[_ZN17EventRecordHandleD5Ev]+0xf): undefined reference to `vtable for EventRecordHandle'
------------------------------------------------------------------ native:test_simpleNameValue [ERRORED] Took 0.53 seconds ------------------------------------------------------------------
========================================================================================== SUMMARY ==========================================================================================
Environment Test Status Duration
native test_util ERRORED 00:00:00.607
native test_emptyDocument ERRORED 00:00:00.668
native test_simpleNameValue ERRORED 00:00:00.527
========================================================================= 3 test cases: 0 succeeded in 00:00:01.802 =========================================================================
Here my platformio.ini
[platformio]
default_envs = native
[env:native]
platform = native
; Needed mostly for testing
test_build_src = true
-D PLATFORM_NATIVE
-D UNITY_INCLUDE_DOUBLE
-D UNITY_DOUBLE_PRECISION=1e-12f
[env:uno]
board = uno
