Compiling mixed C/Cpp code in Main fails after updating from platform 6.13.0 to 7.0.0
Since I updated my environnement through PlatformIo in VScode, my projects don’t compile anymore.
To reproduce the error:
  • A main.cpp file (instead of a main.c) AND
  • Adding an external Pio lib in C AND
  • Platform = espressif32 @ 7.0.x (but compiles fine with version 6.13.0)
Compile error :
Compiling .pio/build/esp32-c3-devkitm-1/libfcc/esp_type_utils/type_utils.o
**cc1: error: command-line option '-fuse-cxa-atexit' is valid for C++/ObjC++ but not for C \[-Werror\]**
Compiling .pio/build/esp32-c3-devkitm-1/libb29/esp_bmp280/bmp280.o
Archiving .pio/build/esp32-c3-devkitm-1/bootloader/esp-idf/spi_flash/libspi_flash.a
Indexing .pio/build/esp32-c3-devkitm-1/bootloader/esp-idf/spi_flash/libspi_flash.a
cc1: all warnings being treated as errors
\*\*\* \[.pio/build/esp32-c3-devkitm-1/libfcc/esp_type_utils/type_utils.o\] Error 1
\*\*\* \[.pio/build/esp32-c3-devkitm-1/libb29/esp_bmp280/bmp280.o\] Error 1
This is my platformio.ini file :
[env:esp32-c3-devkitm-1]
platform = espressif32 @ 7.0.0 ;fails  ;6.13.0 compiles
board = esp32-c3-devkitm-1
framework = espidf
lib_deps = k0i05/esp_bmp280@^1.2.7
I spent I few hours trying to fix this with no luck. I noticed a ESP-IDF GitHub issue that seems similar, but I couldn’t find the changes to the CMakeList to make the work around they suggest: Leaking C++ flags when building together with C only dependency (IDFGH-17629) #18552
Any ideas? Should I report a bug?
Temporary fix by
Adding the tag in PlatformIO as suggested in here worked. Leaking C++ flags when building together with C only dependency (IDFGH-17629) · Issue #18552 · espressif/esp-idf · GitHub
build_unflags = -fuse-cxa-atexit
I openned a bug report Espressif 7.0.x compilation leaks tag -fuse-cxa-atexit for mixed c/cpp projects · Issue #1759 · platformio/platform-espressif32 · GitHub
