Hello There,
Anyone that can help me with the below issue, I just can’t get the marlin build correct.
> Executing task: platformio run <
Processing BIGTREE_SKR_2 (platform: ststm32@~12.1; board: marlin_STM32F407VGT6_CCM; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/marlin_STM32F407VGT6_CCM.html
PLATFORM: ST STM32 (12.1.1) > STM32F407VG (128k RAM, 64k CCM RAM, 1024k Flash
HARDWARE: STM32F407VGT6 168MHz, 128KB RAM, 1MB Flash
DEBUG: Current (stlink) External (jlink, stlink)
- framework-arduinoststm32 0.0.0
- framework-cmsis 2.50501.200527 (5.5.1)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Converting Marlin.ino
Library Manager: Installing TMCStepper @ ~0.7.1
Library Manager: TMCStepper @ 0.7.3 has been installed!
Found 13 compatible libraries
|-- <TMCStepper> 0.7.3
| |-- <SPI> 1.0
| |-- <SoftwareSerial> 1.0
|-- <Adafruit NeoPixel> 1.8.7
|-- <U8glib-HAL> 0.5.1
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <SPI> 1.0
|-- <Servo> 1.1.2
|-- <EEPROM> 2.0.1
|-- <IWatchdog> 1.0.0
|-- <Wire> 1.0
Compiling .pio/build/BIGTREE_SKR_2/FrameworkArduinoVariant/PeripheralPins.c.o
Compiling .pio/build/BIGTREE_SKR_2/FrameworkArduinoVariant/variant.cpp.o
Compiling .pio/build/BIGTREE_SKR_2/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/BIGTREE_SKR_2/FrameworkArduino/HardwareTimer.cpp.o
Assembler messages:
Fatal error: can't create .pio/build/BIGTREE_SKR_2/FrameworkArduinoVariant/PeripheralPins.c.o: No such file or directory
Assembler messages:
Fatal error: can't create .pio/build/BIGTREE_SKR_2/FrameworkArduinoVariant/variant.cpp.o: No such file or directory
*** [.pio/build/BIGTREE_SKR_2/FrameworkArduinoVariant/PeripheralPins.c.o] Error 1
*** [.pio/build/BIGTREE_SKR_2/FrameworkArduinoVariant/variant.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/BIGTREE_SKR_2/FrameworkArduino/HardwareSerial.cpp.o: No such file or directory
*** [.pio/build/BIGTREE_SKR_2/FrameworkArduino/HardwareSerial.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/BIGTREE_SKR_2/FrameworkArduino/HardwareTimer.cpp.o: No such file or directory
*** [.pio/build/BIGTREE_SKR_2/FrameworkArduino/HardwareTimer.cpp.o] Error 1
================================================================ [FAILED] Took 8.40 seconds ================================================================
Environment Status Duration
BIGTREE_SKR_2 FAILED 00:00:08.403
========================================================== 1 failed, 0 succeeded in 00:00:08.403 ==========================================================
The terminal process "platformio 'run'" terminated with exit code: 1.
