Hello all!
Goal - I am trying to automate provisioning the bin.
I want to host a Google Cloud Run container that can generate parameters needed for Google IoT and pass those to Platformio to compile into the binary (such as device id and private key) and copy to a storage bucket so I can later write to an ESP32.
I have a working Dockerfile that installs python and Platformio, installs nodejs (acts as the webserver), and a shell script that exports environment variables which then calls platformio run.
This process works locally, I make a POST to my container and it WORKS. I can take the created bin files and write them to the ESP32 and it works. This ALSO works in GKE as a deployment. I call it the same way. My issue is in Cloud Run I get this error:
Any thoughts on what the issue is (Unknown development environment) or where to properly categorize this issue? I’ve tried these steps but haven’t found any useful debug information. I was going to try StackOverflow and a GCP forum next. Thanks a lot!
Platform.ini
[env:featheresp32]
board = esp32doit-devkit-v1
upload_port = /dev/cu.SLAB_USBtoUART
monitor_port = /dev/cu.SLAB_USBtoUART
'-DDEVICE_ID="${sysenv.DEVICE_ID}"'
'-DPROJECT_ID="${sysenv.PROJECT_ID}"'
'-DPROJECT_LOCATION="${sysenv.PROJECT_LOCATION}"'
'-DREGISTRY_ID="${sysenv.REGISTRY_ID}"'
'-DPRIVATE_KEY="${sysenv.PRIVATE_KEY}"'
Dockerfile
FROM node:14
WORKDIR /usr/src/app
# platformio executable via python doesn't change much. Put it at the beginning to cache off this layer
ENV LC_ALL C.UTF-8
ENV LANG C.UTF-8
RUN apt-get update && apt-get install python3 python3-pip -y
RUN pip3 install -U platformio
# Doesn't change a whole lot right now copy code then install dependencies
COPY new-hardware/lib new-hardware/lib
COPY new-hardware/src new-hardware/src
COPY new-hardware/platformio.ini new-hardware/platformio.ini
WORKDIR /usr/src/app/rom-creator
COPY src/rom-creator/package*.json ./
RUN yarn install --production
COPY src/rom-creator/src/*.ts ./src/
COPY src/rom-creator/tsconfig.json ./
COPY src/rom-creator/create.sh ./
RUN node_modules/.bin/tsc
EXPOSE 8080
CMD [ "node", "dist/index.js" ]
Shell Script
#!/bin/bash
export DEVICE_ID="$1"
export PROJECT_ID="test-55555"
export PROJECT_LOCATION="us-central1"
export REGISTRY_ID="my-registry"
export PRIVATE_KEY="$2"
echo "using this device_id: $DEVICE_ID"
echo "using this private_key: $PRIVATE_KEY"
echo "$REGISTRY_ID"
cd /usr/src/app/new-hardware
platformio update
platformio run -v
