Compiling errors on VSCode using Python 3.10.6, platform ststm32@5.3.0, framework mbed
Hello everyone. I’m trying to build a project targeting a stm32-based board. However, due to my python version (3.10.6) I believe, the following errors happens on building. I’m aware of the following solution from this github issue changing ‘collections’ to ‘collections.abc’, but it doesn’t worked for me.
Details about my machine:
Ubuntu 22.04.2 LTS
Kernel: Linux 5.15.0-67-generic
An snippet of our ‘platformio.ini’ file:
[env:workbench]
platform = ststm32@5.3.0
board = nucleo_f446re
framework = mbed
build_flags = -std=gnu++14 -Wno-register -DDEBUG_BUILD
build_unflags = -std=gnu++98 -std=c++11
upload_protocol = mbed
Error message:
 *  Executing task: platformio run --environment workbench-release
Warning! Ignore unknown configuration option `forecast_platform` in section [env:workbench]
Warning! Ignore unknown configuration option `forecast_platform` in section [env:workbench-release]
Warning! Ignore unknown configuration option `forecast_platform` in section [env:rpc]
Processing workbench-release (platform: ststm32@5.3.0; board: nucleo_f446re; framework: mbed)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f446re.html
PLATFORM: ST STM32 (5.3.0) > ST Nucleo F446RE
HARDWARE: STM32F446RET6 180MHz, 128KB RAM, 512KB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, jlink)
 - framework-mbed @ 5.51105.220603 (5.11.5)
 - toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
ImportError: cannot import name 'Mapping' from 'collections' (/usr/lib/python3.10/collections/__init__.py):
  File "/home/leonardof/.platformio/penv/lib/python3.10/site-packages/platformio/builder/main.py", line 187:
  File "/home/leonardof/.platformio/packages/tool-scons/scons-local-4.4.0/SCons/Script/SConscript.py", line 597:
  File "/home/leonardof/.platformio/packages/tool-scons/scons-local-4.4.0/SCons/Script/SConscript.py", line 285:
  File "/home/leonardof/.platformio/platforms/ststm32/builder/main.py", line 90:
  File "/home/leonardof/.platformio/packages/tool-scons/scons-local-4.4.0/SCons/Util.py", line 737:
  File "/home/leonardof/.platformio/penv/lib/python3.10/site-packages/platformio/builder/tools/piobuild.py", line 60:
    env.ProcessProgramDeps()
  File "/home/leonardof/.platformio/penv/lib/python3.10/site-packages/platformio/builder/tools/piobuild.py", line 120:
  File "/home/leonardof/.platformio/penv/lib/python3.10/site-packages/platformio/builder/tools/piobuild.py", line 331:
    SConscript(env.GetFrameworkScript(name), exports="env")
  File "/home/leonardof/.platformio/packages/tool-scons/scons-local-4.4.0/SCons/Script/SConscript.py", line 660:
    return method(*args, **kw)
  File "/home/leonardof/.platformio/platforms/ststm32/builder/frameworks/mbed.py", line 35:
    SConscript(
  File "/home/leonardof/.platformio/packages/framework-mbed/platformio/platformio-build.py", line 40:
    from pio_mbed_adapter import PlatformioMbedAdapter
  File "/home/leonardof/.platformio/packages/framework-mbed/platformio/pio_mbed_adapter.py", line 23:
    from tools.build_api import (prepare_toolchain, merge_region_list,
  File "/home/leonardof/.platformio/packages/framework-mbed/tools/build_api.py", line 32:
    from jinja2 import FileSystemLoader
  File "/home/leonardof/.platformio/packages/framework-mbed/platformio/package_deps/py3/jinja2/__init__.py", line 33:
    from jinja2.environment import Environment, Template
  File "/home/leonardof/.platformio/packages/framework-mbed/platformio/package_deps/py3/jinja2/environment.py", line 16:
    from jinja2.defaults import BLOCK_START_STRING, \
  File "/home/leonardof/.platformio/packages/framework-mbed/platformio/package_deps/py3/jinja2/defaults.py", line 32:
    from jinja2.tests import TESTS as DEFAULT_TESTS
  File "/home/leonardof/.platformio/packages/framework-mbed/platformio/package_deps/py3/jinja2/tests.py", line 13:
    from collections import Mapping
========================================================================== [FAILED] Took 0.49 seconds ==========================================================================
Environment        Status    Duration
workbench-release  FAILED    00:00:00.488
==================================================================== 1 failed, 0 succeeded in 00:00:00.488 ====================================================================
 *  The terminal process "platformio 'run', '--environment', 'workbench-release'" terminated with exit code: 1.
