Hi there.
A coupke of days ago I transitioned from the Arduino IDE (making long programs in there was a nightmare) to VSCode with platformIO.
The problem now (that has happened to me in many other libraries) is that when I compile code that was copied from and Arduino IDE sketch the code compiles OK but it throws errrors on the libraries (which have not been modified by me).
Let me give you an example. Using TinyGSM library and its MQTT example. The code works fine on Arduino IDE and when I compile in platformIO it throws this errrors:
> Executing task in folder test gsm: platformio.exe run <
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR 1.15.0 > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
PACKAGES: toolchain-atmelavr 1.50400.190710 (5.4.0), framework-arduinoavr 4.1.1
Found 16 compatible libraries
|-- <PubSubClient> 2.7
|-- <TinyGSM> 0.9.7
Compiling .pio\build\megaatmega2560\src\main.cpp.o
Archiving .pio\build\megaatmega2560\lib314\libPubSubClient_ID89.a
Compiling .pio\build\megaatmega2560\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\megaatmega2560\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\megaatmega2560\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\megaatmega2560\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pio\build\megaatmega2560\FrameworkArduino\Print.cpp.o
Compiling .pio\build\megaatmega2560\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\megaatmega2560\FrameworkArduino\Tone.cpp.o
In file included from C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:31:0,
from C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmClientSIM800.h:22,
from C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmClientSIM808.h:13,
from C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmClient.h:24,
from src\main.cpp:95:
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmFifo.h: In function 'void loop()':
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmFifo.h:4:1: error: a template declaration cannot appear at block scope
template <class T, unsigned N>
In file included from C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmClientSIM800.h:22:0,
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:57:11: error: expected identifier before '{' token
namespace {
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:58:3: error: a template declaration cannot appear at block scope
template<typename T>
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:70:3: error: a template declaration cannot appear at block scope
template<typename... Args>
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:83:1: error: a template declaration cannot appear at block scope
template<class T>
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:95:1: error: a template declaration cannot appear at block scope
template<class T>
C:\Users\marti\appdata\roaming\spb_data\.platformio\lib\TinyGSM_ID1287\src/TinyGsmCommon.h:142:44: error: a function-definition is not allowed here before '{' token
String TinyGsmDecodeHex7bit(String &instr) {
src\main.cpp:84:12: warning: unused variable 'apn' [-Wunused-variable]
const char apn[] = "telefonica.es";
src\main.cpp:85:12: warning: unused variable 'user' [-Wunused-variable]
const char user[] = "telefonica";
src\main.cpp:86:12: warning: unused variable 'pass' [-Wunused-variable]
const char pass[] = "telefonica";
src\main.cpp:89:13: warning: unused variable 'broker' [-Wunused-variable]
const char* broker = "test.mosquitto.org";
src\main.cpp:91:13: warning: unused variable 'topicLed' [-Wunused-variable]
const char* topicLed = "GsmClientTest/led";
src\main.cpp:92:13: warning: unused variable 'topicInit' [-Wunused-variable]
const char* topicInit = "GsmClientTest/init";
src\main.cpp:93:13: warning: unused variable 'topicLedStatus' [-Wunused-variable]
const char* topicLedStatus = "GsmClientTest/ledStatus";
src\main.cpp:239:1: error: expected '}' at end of input
*** [.pio\build\megaatmega2560\src\main.cpp.o] Error 1
=============================================================================================== [ERROR] Took 4.24 seconds ===============================================================================================
As you can see the errors appear on the library files.
