I’m using some code on github which I want to get compiling under PIO. I am trying to make some changes to the code and thought it would be better to get it going with PIO.
https://github.com/terenceang/SDisk2/tree/master/firmware/src
First off, there is a makesdisk.sh file which if I manually run compiles the code without any errors for the atmega328.
If I try and build it using PIO I run into all sorts of compile errors.
Processing ATmega328 (platform: atmelavr; board: ATmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega328.html
PLATFORM: Atmel AVR (3.4.0) > ATmega328
HARDWARE: ATMEGA328 270MHz, 2KB RAM, 32KB Flash
- framework-arduino-avr-minicore @ 2.1.3
Found 8 compatible libraries
Compiling .pio/build/ATmega328/src/FAT32.c.o
Compiling .pio/build/ATmega328/src/SD_routines.c.o
Compiling .pio/build/ATmega328/src/SPI_routines.c.o
Compiling .pio/build/ATmega328/src/main.c.o
Compiling .pio/build/ATmega328/src/oled.c.o
In file included from src/main.h:60:0,
from src/main.c:37:
src/oled.h:78:26: error: unknown type name 'prog_char'
void ssd1306_put_p(const prog_char *progmem_s);
src/main.c:122:15: error: unknown type name 'prog_uchar'
Beginner c user here. If I google those errors it points to a depreciated command - is this why its working with bash script and not PIO?
The bash script is passing a lot of compiler parameters.
-Wall -Os -Wno-deprecated-declarations -Wno-strict-aliasing
-D__PROG_TYPES_COMPAT__ -D_SDISK_OLED_ -fpack-struct -fshort-enums
-std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p
-DF_CPU=27000000UL -MMD -MP -c
I’m taking a few stabs in the dark and guessing it might be related tno-deprecated-declarations flag?
I then tried the following flags in the platform.io file but this has not helped.
[env:ATmega328]
board = ATmega328
upload_protocol = usbtiny
board_build.f_cpu = 270000000L
build_flags = -Wall -Os -Wno-deprecated-declarations -Wno-strict-aliasing
Can anyone point me in the right direction before I go down another rabbit hole.
