The problem:
- My project when compiled on my Windows laptop, no longer runs on my Cheap Yellow Display. (The screen is just white(There are no errors and everything goes as expected) When I compile and upload using Linux it works OK.
- When I start monitoring I get:
indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
Click to see monitor log
07:16:44.988 > 0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
07:16:44.991 > configsip: 0, SPIWP:0xee
07:16:44.991 > clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
07:16:44.998 > mode:DIO, clock div:2
07:16:44.998 > load:0x3fff0030,len:4744
07:16:45.003 > load:0x40078000,len:15712
07:16:45.003 > load:0x40080400,len:3152
07:16:45.003 > entry 0x4008059c
07:16:45.403 > LVGL_CYD version: 1.2.2
07:16:45.403 > TFT_eSPI version: 2.5.43
07:16:45.403 > LVGL version: 9.3.0
07:16:45.416 > E (15) gpio: gpio_pulldown_en(116): GPIO number error (input-only pad has no internal PD)
07:16:45.418 > Resistive touch detected
07:16:45.418 > ILI9341 detected
07:16:45.433 > [ 41][E][esp32-hal-cpu.c:128] addApbChangeCallback(): duplicate func=0x401263ec arg=0x3ffbddf8
07:16:46.412 > [Warn] (1.020, +1020) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.471 > [Warn] (1.084, +64) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.502 > [Warn] (1.114, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.534 > [Warn] (1.144, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.550 > [Warn] (1.174, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.592 > [Warn] (1.204, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.623 > [Warn] (1.234, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.646 > [Warn] (1.264, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.678 > [Warn] (1.294, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.709 > [Warn] (1.324, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.741 > [Warn] (1.354, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.773 > [Warn] (1.384, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.804 > [Warn] (1.414, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.836 > [Warn] (1.444, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.865 > [Warn] (1.474, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.895 > [Warn] (1.504, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.925 > [Warn] (1.534, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.956 > [Warn] (1.564, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:46.985 > [Warn] (1.594, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.015 > [Warn] (1.624, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.045 > [Warn] (1.654, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.076 > [Warn] (1.684, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.106 > [Warn] (1.714, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.135 > [Warn] (1.744, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.166 > [Warn] (1.774, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.195 > [Warn] (1.804, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.226 > [Warn] (1.834, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.256 > [Warn] (1.864, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.285 > [Warn] (1.894, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.316 > [Warn] (1.924, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.346 > [Warn] (1.954, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.376 > [Warn] (1.984, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.405 > [Warn] (2.014, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.436 > [Warn] (2.044, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.465 > [Warn] (2.074, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.495 > [Warn] (2.104, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.526 > [Warn] (2.134, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.556 > [Warn] (2.164, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.586 > [Warn] (2.194, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.616 > [Warn] (2.224, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.645 > [Warn] (2.254, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.676 > [Warn] (2.284, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.706 > [Warn] (2.314, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.736 > [Warn] (2.344, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.766 > [Warn] (2.374, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.795 > [Warn] (2.404, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.825 > [Warn] (2.434, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.856 > [Warn] (2.464, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.885 > [Warn] (2.494, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.916 > [Warn] (2.524, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.945 > [Warn] (2.554, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:47.975 > [Warn] (2.584, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.006 > [Warn] (2.614, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.036 > [Warn] (2.644, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.066 > [Warn] (2.674, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.095 > [Warn] (2.704, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.126 > [Warn] (2.734, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.155 > [Warn] (2.764, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.185 > [Warn] (2.794, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.215 > [Warn] (2.824, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.246 > [Warn] (2.854, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.276 > [Warn] (2.884, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.306 > [Warn] (2.914, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.335 > [Warn] (2.944, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.365 > [Warn] (2.974, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.396 > [Warn] (3.004, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.425 > [Warn] (3.034, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.455 > [Warn] (3.064, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.485 > [Warn] (3.094, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.515 > [Warn] (3.124, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.545 > [Warn] (3.154, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.576 > [Warn] (3.184, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.606 > [Warn] (3.214, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.636 > [Warn] (3.244, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.666 > [Warn] (3.274, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.695 > [Warn] (3.304, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.725 > [Warn] (3.334, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.756 > [Warn] (3.364, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.786 > [Warn] (3.394, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.815 > [Warn] (3.424, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
07:16:48.845 > [Warn] (3.454, +30) indev_pointer_proc: X is -1 which is smaller than zero lv_indev.c:714
- This has started only several days ago. Prior to that I was compiling and uploading from Windows without any issues. (I’m unaware of any changes to the system that would affect this but am asking here to get some pointers on what the next steps are to troubleshoot this issue.
Steps I’ve taken:
- Ran
Full Clean
Any help is appreciated!
