Compiler suddenly throwing a “argument of type ‘NoneType’ is not iterable” on line 0 of platformio.ini, when using the following variable interpolation syntax (previously compiling fine before today)
[env]
platform = espressif8266
board = esp12e
[env:Lollypops]
build_flags = -D SOMEFLAG
!echo "-D FIRMWARE_VERSION="${FIRMWARE_VERSION}
See this documentation
https://docs.platformio.org/en/latest/projectconf/interpolation.html
Thanks for your reply. Changed that, deleted .platformio cache directory, but still happening.
Okay found what’s happening. It’s actually due to using this syntax to output build flags:
[env:Lollypops]
!echo “-D FIRMWARE_VERSION=”${FIRMWARE_VERSION}
This used to work?
Looks like environment variables now need to be prefixed with sysenv ie
[env:Lollypops]
!echo "-D FIRMWARE_VERSION="${sysenv.FIRMWARE_VERSION}
A nicer error msg please, powers that be!
