Compiler failed to find function definitions for header with adjacent source (undefined reference)
When I’m compiling a simple main.cpp (atmelavr platform) #included header and source in separate but adjacent file, linker fails to find the source and returns error code 1.
File tree:
├── include
│   ├── README
│   ├── hd.cxx
│   └── hd.hxx
├── lib
│   └── README
├── platformio.ini
├── src
│   └── main.cpp
└── test
    └── README
include/hd.hxx:
void run();
namespace T
    void run();
class Test
public:
    Test();
include/hd.cxx:
#include "hd.hxx"
void run()
void T::run()
Test::Test()
src/main.cpp:
#include "hd.hxx"
  // put your main code here, to run once:
  run();
  T::run();
  Test();
All three calls in setup() causes linker to fail.
Verbose build output:
> Executing task: platformio run --verbose <
Processing megaatmega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino; upload_port: /dev/cu.usbmodem1471201)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR 2.0.0 > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
 - framework-arduino-avr 5.0.0
Found 5 compatible libraries
avr-g++ -o .pio/build/megaatmega2560/firmware.elf -Os -mmcu=atmega2560 -Wl,--gc-sections -flto -fuse-linker-plugin .pio/build/megaatmega2560/src/main.cpp.o -L.pio/build/megaatmega2560 -Wl,--start-group .pio/build/megaatmega2560/libFrameworkArduinoVariant.a .pio/build/megaatmega2560/libFrameworkArduino.a -lm -Wl,--end-group
/var/folders/y2/kqr2bn7j3bqbb6xh3wqw1xxc0000gn/T//ccFrvf93.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0xea): undefined reference to `run()'
<artificial>:(.text.startup+0xee): undefined reference to `T::run()'
<artificial>:(.text.startup+0xf6): undefined reference to `Test::Test()'
*** [.pio/build/megaatmega2560/firmware.elf] Error 1
================================== [FAILED] Took 0.63 seconds ==================================
platformio.ini if needed:
[env:megaatmega2560]
board = megaatmega2560
upload_port = /dev/cu.usbmodem1471201
Why separated header and source file can be compiled if it is a library but can’t if it is in include directory?
Does anyone have idea?
Don’t put hd.cxx in include, put it in src.
See also Use headers give me an error - #7 by DrakoPD
Aww thanks so much!
It works now.
