I tried to compile the following code on Visual Studio Code with the PIO extension for an Arduino UNO R4 WiFi:
#include <SoftwareSerial.h>
#define rx_Pin 10
#define tx_Pin 11
#define DE_Pin 3
#define RE_Pin 4
#define LED 13
SoftwareSerial RS485_Serial = SoftwareSerial(rx_Pin, tx_Pin);
const char compile_date[] = __DATE__ " " __TIME__; // Built Information
// declare functions
void serialHandler();
void statemachine_RS485_com();
void serialEvent();
void _debug();
// Definition f states
enum comstates{
com_standby,
com_send,
com_receive,
com_timeout = 90
// input string
String input_string = "h";
bool input_serialHandler = true;
// init states
uint8_t com_state = com_standby;
uint32_t com_state_timer = 0;
// com_states variables
pinMode(rx_Pin, INPUT);
pinMode(tx_Pin, OUTPUT);
pinMode(DE_Pin, OUTPUT);
pinMode(RE_Pin, OUTPUT);
digitalWrite(DE_Pin, HIGH);
digitalWrite(RE_Pin, HIGH);
RS485_Serial.begin(19200);
__debug(F("RS485_statemachine_R4"));
__debug("built: " + (String)compile_date);
__debug("");
if (input_serialHandler) {
serialHandler();
input_string="";
input_serialHandler = false;
void serialHandler() {
switch (input_string.charAt(0)) {
case 'h':
_debug(F("######################"));
_debug(F("h - display this help"));
break;
case 'i':
break;
default:
_debug("serialHandler|unknown command|" + input_string);
break;
void statemachine_RS485_com () {
switch (com_state) {
case com_standby:
/* code */
break;
default:
break;
void serialEvent() {
while (Serial.available()) {
char inChar = (char)Serial.read();
if (inChar == 10) {
else if (isAlphaNumeric(inChar)) {
input_string += inChar;
String _convert_unsigned_long_to_String(unsigned long input, int ziellaenge) {
String converttemp = (String)input;
while (converttemp.length() < ziellaenge) {
converttemp = " " + converttemp;
return converttemp;
void _debug(String _debugtext) { // _debuging
Serial.println(_convert_unsigned_long_to_String(millis(), 6) + "|" + _debugtext);
The code compiles fine on the Arduino IDE but on PIO I get the following errors:
rc/main.cpp: In function 'void serialHandler()':
src/main.cpp:75:39: error: too many arguments to function 'void _debug()'
src/main.cpp:25:6: note: declared here
void _debug();
src/main.cpp:76:38: error: too many arguments to function 'void _debug()'
void _debug();
src/main.cpp:77:44: error: too many arguments to function 'void _debug()'
void _debug();
src/main.cpp:78:39: error: too many arguments to function 'void _debug()'
void _debug();
src/main.cpp:79:38: error: too many arguments to function 'void _debug()'
void _debug();
src/main.cpp:86:59: error: too many arguments to function 'void _debug()'
void _debug();
What am i doing wrong?
