I wrote a program just over a year ago for an ATtiny13a and it compiled.
I tried to compile it again just now and the compile size has just tipped past the 1024 byte size.
I read another post My PlatformIO Projects Now Compile With Errors And I Cannot Figure Out Why?
This seems to point to my not specifying a platform version in the platformio.ini. Are you able to point me in the right direction so I can use a specific past version?
Also - how do I fix the compile size for my other projects moving forwards?
My platformio.ini
[env:attiny13a]
board = attiny13a
; device is USBASP V2.0 with updated firmware
upload_protocol = custom
upload_port = usb
upload_flags =
-C
; use "tool-avrdude-megaavr" for the atmelmegaavr platform
${platformio.packages_dir}/tool-avrdude/avrdude.conf
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
usbasp
I’m getting closer to a solution - found this post https://community.platformio.org/t/how-to-specify-desired-version-of-an-installed-framework/21970/1
I think I need to use
platform = atmelavr@x.y.z
but where do I find a history of past stable versions to try?
And then I found this https://github.com/platformio/platform-atmelavr/releases
I edited my platformio.ini to include
[env:attiny13a]
; platform = atmelavr
platform = atmelavr@5.0.0
board = attiny13a
and then did a recompile…
Processing attiny13a (platform: atmelavr@5.0.0; board: attiny13a; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------Platform Manager: Installing atmelavr @ 5.0.0
Platform Manager: atmelavr@5.0.0 has been installed!
Tool Manager: Installing platformio/framework-arduino-avr-microcore @ ~2.3.0
Tool Manager: framework-arduino-avr-microcore@2.3.0 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/attiny13a.html
PLATFORM: Atmel AVR (5.0.0) > ATtiny13A
HARDWARE: ATTINY13A 9MHz, 64B RAM, 1KB Flash
DEBUG: Current (simavr) External (simavr)
- framework-arduino-avr-microcore @ 2.3.0
Found 7 compatible libraries
|-- EEPROM @ 2.0
Compiling .pio\build\attiny13a\src\main.cpp.o
Archiving .pio\build\attiny13a\libFrameworkArduinoVariant.a
Compiling .pio\build\attiny13a\FrameworkArduino\HalfDuplexSerial.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\Print.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\attiny13a\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\WString.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\main.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\micros.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\millis.S.o
Compiling .pio\build\attiny13a\FrameworkArduino\pcrt.S.o
Compiling .pio\build\attiny13a\FrameworkArduino\picoUART.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\picoUART_rxISR.cpp.o
Compiling .pio\build\attiny13a\FrameworkArduino\wiring.c.o
Compiling .pio\build\attiny13a\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\attiny13a\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\attiny13a\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\attiny13a\FrameworkArduino\wiring_pwm.c.o
Compiling .pio\build\attiny13a\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\attiny13a\libFrameworkArduino.a
Linking .pio\build\attiny13a\firmware.elf
Checking size .pio\build\attiny13a\firmware.elf
RAM: [=== ] 31.2% (used 20 bytes from 64 bytes)
Flash: [==========] 95.7% (used 980 bytes from 1024 bytes)
Building .pio\build\attiny13a\firmware.hex
=============================================================== [SUCCESS] Took 39.98 seconds =============================================================== * Terminal will be reused by tasks, press any key to close it.
Happy days, 980 bytes - back the right side of 1024.
