I have a project and I want to use a library which is not a PlatformIO library; it has no manifest. The library must only be compiled and linked in some environments, not all.
I tried putting the library outside the project and using lib_dep = symlink://../LIBRARY
but I get an error: MissingPackageManifestError: Could not find one of 'library.json, library.properties, module.json' manifest files in the package
I’d like to try putting the library inside the project under lib/
but I can’t find any way to compile and link the library in only some environments. I’ve looked all through the documentation but I can’t find anything analogous to build_src_filter
for files under the lib/
subdirectory.
Is there a way to do this? Or should I file a GitHub™ issue?
Thanks,
rah
