I have a lot of sketches for the ESP8266 all working fine. Now I have a little test sketch that fails.
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 (2024.1.1) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 2.7.6
- tool-esptoolpy @ 1.40700.0 (4.7.0)
- toolchain-xtensa @ 2.40802.200502 (4.8.2)
Found 28 compatible libraries
|-- DHT sensor library for ESPx @ 1.19.0
*** [.pio/build/esp12e/firmware.elf] Implicit dependency `/Users/mk/.platformio/platforms/espressif8266/builder/=' not found, needed by target `.pio/build/esp12e/firmware.elf'.
============================================== [FAILED] Took 1.41 seconds ==============================================
platformio.ini starts the same as all others
[env:esp12e]
platform = espressif8266
board = esp12e
Why can I compile more then a dozend programs partly huge successfull, but not a small one?
