after reinstalling the pc, the previously legally copied project shows these errors. Can you advise please?
framework-arduino-lpc176x @ 0.2.9
toolchain-gccarmnoneeabi @ 1.110301.0 (11.3.1)
Converting Marlin.ino
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 3 compatible libraries
Scanning dependencies…
|-- Servo @ 1.0.0
|-- TMCStepper @ 0.7.3
|-- U8glib-HAL @ 0.5.2
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\MarlinSerial.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\MinSerial.cpp.o
In file included from c:\users\42073.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\11.3.1\utility:68,
from c:\users\42073.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\11.3.1\array:38,
from C:\Users\42073.platformio\packages\framework-arduino-lpc176x\cores\arduino/HardwareSerial.h:26,
from Marlin\src\HAL\LPC1768\MarlinSerial.h:24,
from Marlin\src\HAL\LPC1768\MarlinSerial.cpp:24:
c:\users\42073.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\11.3.1\bits\c++config.h:430:10: fatal error: bits/os_defines.h: No such file or directory
430 | #include <bits/os_defines.h>
compilation terminated.
*** [.pio\build\LPC1769\src\src\HAL\LPC1768\MarlinSerial.cpp.o] Error 1
from c:\users\42073.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\11.3.1\algorithm:60,
from d:\fv_scube-2023-4 aktual\marlin\src\hal\lpc1768\hal.h:33,
from Marlin\src\HAL\LPC1768../…/inc/…/HAL/HAL.h:30,
from Marlin\src\HAL\LPC1768../…/inc/MarlinConfig.h:31,
from Marlin\src\HAL\LPC1768\HAL_SPI.cpp:51:
*** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o] Error 1
from Marlin\src\HAL\LPC1768\MinSerial.cpp:24:
from Marlin\src\HAL\LPC1768\HAL.cpp:24:
*** [.pio\build\LPC1769\src\src\HAL\LPC1768\MinSerial.cpp.o] Error 1
*** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o] Error 1
============================================================ [FAILED] Took 3.40 seconds ============================================================
*** [.pio/build/LPC1768/src/src/HAL/LPC1768/eeprom_wired.cpp.o] Error 1
In file included from /Users/kamaczka/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/11.3.1/algorithm:60,
from Marlin/src/HAL/LPC1768/../../inc/../HAL/./LPC1768/HAL.h:33,
from Marlin/src/HAL/LPC1768/../../inc/../HAL/HAL.h:30,
from Marlin/src/HAL/LPC1768/../../inc/MarlinConfig.h:31,
from Marlin/src/HAL/LPC1768/fast_pwm.cpp:24:
/Users/kamaczka/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/11.3.1/utility:68:10: fatal error: bits/c++config.h: No such file or directory
68 | #include <bits/c++config.h>
I’ve already reinstalled, deleted, the stuff as suggested in other threads
Aha. So that’s weird. Per PlatformIO Registry the 11.3.1 version was only released a day ago, but the platform is already automatically using it? Sounds like someone just made an error in the version declaration of their custom platform.json. That doesn’t seem right, it’ll probably want a stable version.
Can you please add or find the platform_packages declaration for your selected environment (LPC1769) and add / modify it to fix the toolchain version to the previous one?
Yeah, this is absolutely deadly what they did in the pio-nxplpc-arduino-lpc176x platform.
That’ll just take the highest version after or equal to 6.3.1, without having it ever tested. There’s no < x.y.z constraint.
CC @ivankravets critical for Marlin LPC176x compilation.
Overall I find it weird that with that toolchain, #include <algorithm> doesn’t work at all, it should be a standard header. Maybe the uploaded toolchain is broken in this regard?
The offending 110301 package version was removed (renamed to by -teensy specific since that what it is) and thus compilation should be restored without any modifications.
