#include<H4Plugins.h> // << Includes Arduino.h internally.
H4_USE_PLUGINS(115200,20,false) // Serial baud rate, Q size, SerialCmd autostop
H4P_FlasherController h4fc;
Tested on STM32NUCLEO-F429ZI that has red, green dn blue LEDs onboard.
You will probably need to wire your own
and e.g #define LED_RED 99, LED_GREEN 23... etc
#define LED_RED 20
#define LED_GREEN 27
#define LED_BLUE 14
void h4setup() { // H4 constructor starts Serial
Serial.println("H4P_FlasherController Basic Example v"H4P_VERSION);
pinMode(LED_RED,OUTPUT); // not required if H4P_GPIOManager used
pinMode(LED_GREEN,OUTPUT);// not required if H4P_GPIOManager used
pinMode(LED_BLUE,OUTPUT);// not required if H4P_GPIOManager used
h4.everyRandom(5000,10000,[](){
Serial.print(millis());Serial.println(" RUDE INTERRUPTION");
h4fc.pulseLED(100,LED_BLUE);
},nullptr,4);
h4fc.flashLED(250,LED_GREEN);
h4fc.flashMorse("... --- ...",150,LED_RED);
If you follow the definitions of VSCode for Serial and then into Stream and then into Print you will see that the library provides its own Print.h version
which overrides and conflicts with the Arduino-ESP32’s Print.h version. The library’s version gets included before the Arduino-ESP32’s core one.
Checking size .pio\build\esp32doit-devkit-v1\firmware.elf
RAM: [= ] 6.5% (used 21172 bytes from 327680 bytes)
Flash: [==== ] 37.7% (used 494363 bytes from 1310720 bytes)
esptool.py v3.0
================ [SUCCESS] Took 24.02 seconds ================
The library is attempting to fill in Arduino functionality on other platforms while overwriting the core’s functionality. The Print.h header should be called something differently to not conflict with the core, or do a #include_next if it detects that it’s running in the Arduino framework.
The Arduino IDE probably gets lucky having a different order of -I include flags that prioritizes the core’s files instead of the library one’s.
The pure existence of the file Print.h is the problem, it has 0 to do with if the file is being used by the library. The problem is that the way PlatformIO orders the -I include flags, when another library is built such as these plugins, the include order will be Arduino.h -> HardwareSerial.h -> Stream.h -> Print.h (from H4 library) and in that version there’s no printf().
In hindsight I thought of another thing: The library creates this Print.h header so that the printing API is unified across all platforms, like Linux Desktop, STM32, Raspbi, ESP8266. So a library should probably also only ever used this “agreed upon” API and do it with Serial.println() calls with the formatting being done by + String(someIntParam) etc. Either that or expand the Print.handPrint.cpp and check if printf() is also available on all other platforms, to ensure compilibility in all cases.
I see, It’s somehow PIO related issue, about build-system, where 99.99% of the cases won’t be any issue.
Can I re-order Includes in some-way at building stage, maybe using platformio.ini ?
Because It’s preferable also that we use core’s libraries instead of adding to the binary size.
I think it’s the straight-forward solution, How do you think ?
Well if you do fix the include order to use the core’s library, again you run into this issue where it’s e.g. not implemented by the AVR version of the Arduino core and fails to compile.
And what speaks against “expansion” of the printing API with printf() is that printf() is extremely large in flash and RAM, single String() conversions should be less intensive.
I can’t see it a problem, where the library doesn’t support AVR boards in the essence.
For what’s matter, printf is hugely preferable to me over print,println. as it’s mainly used for debugging, Usage is straight-forward and makes the code ‘neat’ .
Thank you for the suggestion, I’ll file the issue to platformio-core repo very soon.
