After updating one of my libraries, PIO seems to not be able to find them all, even though they are still installed. (at least that is my rudimentary understanding of what is going on… might be totally off base).
How do I fix?
Here is the terminal log from an attempt to compile. This worked fine for weeks up until I updated the Adafruit unified sensor library.
> Executing task in folder Humidifier Control 2.0: C:\Users\teook\.platformio\penv\Scripts\platformio.exe run <
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz 80KB RAM (4MB Flash)
Collected 34 compatible libraries
|-- <ArduinoOTA> 1.0
| |-- <ESP8266WiFi> 1.0
| | |-- <ArduinoBearSSL> 1.2.0
| |-- <ESP8266mDNS>
|-- <Adafruit Unified Sensor> 1.0.2
|-- <ESP8266WebServer> 1.0
|-- <WebSockets> 2.1.3
| |-- <Ethernet(esp8266)> 1.0.4
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Hash> 1.0
|-- <DHT sensor library> 1.3.1
|-- <WifiManager> 0.14
| |-- <DNSServer> 1.1.0
Compiling .pioenvs\nodemcuv2\lib22c\ArduinoBearSSL_ID5571\BearSSLClient.cpp.o
Compiling .pioenvs\nodemcuv2\lib22c\ArduinoBearSSL_ID5571\bearssl\aes_pwr8_ctrcbc.c.o
Compiling .pioenvs\nodemcuv2\lib22c\ArduinoBearSSL_ID5571\bearssl\aes_small_cbcdec.c.o
Compiling .pioenvs\nodemcuv2\lib22c\ArduinoBearSSL_ID5571\bearssl\aes_small_cbcenc.c.o
C:\Users\teook\.platformio\lib\ArduinoBearSSL_ID5571\src\BearSSLClient.cpp:25:27: fatal error: ArduinoECCX08.h: No such file or directory
* Looking for ArduinoECCX08.h dependency? Check our library registry!
* CLI > platformio lib search "header:ArduinoECCX08.h"
* Web > https://platformio.org/lib/search?query=header:ArduinoECCX08.h
#include <ArduinoECCX08.h>
compilation terminated.
*** [.pioenvs\nodemcuv2\lib22c\ArduinoBearSSL_ID5571\BearSSLClient.cpp.o] Error 1
============================================================= [ERROR] Took 8.88 seconds =============================================================
