Compilation error
Hi Guys!
I can’t compile a project.
main.cpp
#include <EEPROM.h>
#include "connection.h"
Connection connection;
void setup()
Serial.begin(9600);
connection.setTest(1);
void loop()
Serial.println(connection.getTest());
delay(1000);
connection.cpp
class Connection
private:
    int test;
public:
    void setTest(int val)
        test = 1;
    int getTest()
        return test;
connection.h
#ifndef CONNECTION_H
#define CONNECTION_H
class Connection
private:
    int test;
public:
    void setTest(int val);
    int getTest();
#endif // CONNECTION_H
platformio.ini
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
upload_speed = 115200
error
Linking .pio\build\nodemcuv2\firmware.elf
c:/users/zzz/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\nodemcuv2\src\main.cpp.o:(.text.setup+0xc): undefined reference to `Connection::setTest(int)'
c:/users/zzz/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\nodemcuv2\src\main.cpp.o: in function `setup':
main.cpp:(.text.setup+0x3a): undefined reference to `Connection::setTest(int)'
c:/users/zzz/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\nodemcuv2\src\main.cpp.o:(.text.loop+0x0): undefined reference to `Connection::getTest()'
c:/users/zzz/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\nodemcuv2\src\main.cpp.o:(.text.loop+0xd): undefined reference to `Connection::getTest()'
*** [.pio\build\nodemcuv2\firmware.elf] Error 1
Can somebody help?
Your connection.cpp is wrong. You’re redeclaring a class (the same as in connection.h) but then you implement the functions of it. Together with the connection.h you have a double declaration and the compiler gets confused… Write connection.cpp like this:
#include <connection.h>
void Connection::setTest(int val)
	test = 1; //note by me: it's unclear here why you don't assign val
int Connection::getTest()
	return test;
See reference
You can btw also do it as a header-only implementation. For that, delete connection.cpp and write conection.h as
class Connection
private:
    int test;
public:
    void setTest(int val) {
    	test = 1;
    int getTest() {
    	return test;
However, the header-and-source-file way is way cleaner and doesn’t require pulling in the entire code when the header is included. You should prefer the first way.
