The latest PlatformIO 4.0.0a9 creates an issue when using [common] section inside PlatformIO.ini
Build error:
You can ignore this message, if {'requirements': None, 'name': '${common.lib_deps}'}
is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 > Espressif ESP32 Dev Module
HARDWARE: ESP32 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny,
tumpa)
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Collected 37 compatible libraries
Scanning dependencies…
*** ValueError invalid literal for int() with base 10: ''' trying to evaluate
${__get_board_f_flash(env)}’
File “C:\Users\NEF.platformio\platforms\espressif32\builder\main.py”, line 281, in
[ERROR] Took 1.88 seconds
platformio.ini
[platformio]
env_default = stable
src_dir = ./
lib_dir = …/…/…/Libraries[common]
lib_ignore =board_build.f_cpu = 240000000L
board_build.f_flash = 80000000L
;board_build.partitions =
upload_speed = 921600
-DLOG_LOCAL_LEVEL=ESP_LOG_DEBUG
-DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_DEBUG
build_unflags =[env:stable]
framework = arduinolib_ignore = ${common.lib_ignore}
lib_deps = ${common.lib_deps}
upload_speed = ${common.upload_speed}
build_flags = ${common.build_flags}
build_unflags = ${common.build_unflags}board_build.f_cpu = ${common.board_build.f_cpu}
board_build.f_flash = ${common.board_build.f_flash}
;board_build.partitions = ${common.board_build.partitions}
