In my platformio.ini I set up two environments, one for release [env:RELEASE] and one for debug [env:DEBUG]. In section [common], there are extra_scripts defined…
The release environment includes these scripts via the line extra_scripts = ${common.extra_scripts} and this works fine when default_env = RELEASE.
However in the debug environment extra_scripts does NOT reference the [common] section values but yet these scripts run anyway when default_env=DEBUG !
I would not expect those [common] scripts to run when using the DEBUG env.
Here’s the file:
[platformio]
default_envs = DEBUG
[common]
-fmax-errors=4
-g3
-ggdb
-Wno-missing-braces
extra_scripts =
pre:buildroot/scripts/custom_filename.py
post:buildroot/scripts/short_out_filename.py
[env:RELEASE]
platform = ststm32@11.0.0
framework = cmsis
board = btt_tft35_v3
${stm32f2xx.build_flags}
-DSTM32F2XX=
-DHSE_VALUE=8000000ul
-DVECT_TAB_FLASH=0x08008000
-DRAM_SIZE=48
extra_scripts = ${common.extra_scripts} ; use scripts from [common]
[env:BIGTREE_TFT35_V3_0 DEBUG]
framework = cmsis
upload_protocol = stlink
-DSTM32F2XX=
-DRAM_SIZE=48
extra_scripts =
buildroot/scripts/stm32f2xx_0x8000_iap.py
build_type = debug
debug_tool = stlink
Anyone seen this behavior before?
