Command pio boards return error when project contains boards folder
When I run the command
pio board
I get this error
MacBook-Pro:Actuator_Test j***$ pio boards
AssertionError: Traceback (most recent call last):
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/__main__.py", line 103, in main
    cli()  # pylint: disable=no-value-for-parameter
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/click/core.py", line 1157, in __call__
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/click/core.py", line 1078, in main
    rv = self.invoke(ctx)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/cli.py", line 85, in invoke
    return super().invoke(ctx)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/click/core.py", line 1688, in invoke
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/click/core.py", line 1434, in invoke
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/click/core.py", line 783, in invoke
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/commands/boards.py", line 34, in cli
    for board in _get_boards(installed):
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/commands/boards.py", line 75, in _get_boards
    return pm.get_installed_boards() if installed else pm.get_all_boards()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/manager/platform.py", line 124, in get_all_boards
    boards = self.get_installed_boards()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/util.py", line 56, in wrapper
    self.cache[key] = (time.time(), func(*args, **kwargs))
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/manager/platform.py", line 112, in get_installed_boards
    for config in p.get_boards().values():
  File "/Users/***.platformio/platforms/atmelsam/platform.py", line 105, in get_boards
    result[key] = self._add_default_debug_tools(result[key])
  File "/Users/***.platformio/platforms/atmelsam/platform.py", line 154, in _add_default_debug_tools
    assert openocd_chipname
AssertionError
  `python -m pip install -U platformio` command
the error only happens when the folder “boards” is present in the project’s root
This is normal. Please remove the broken board manifest located in the “boards” folder.
the manifest is a copy of one found in /.platformio/platforms/ststm32/boards with a different name :
rumba32_f446ve.json copied into the /.platformio/boards directory and renamed jld_f446ve.json
