Full error code: collect2.exe: error: ld returned 1 exit status
*** [.pio\build\nanoatmega328\firmware.elf] Error 1
Project code: https://github.com/SaV91/LaserTagGame.git
Please help
Please help
Ok! I checked out your github and found the screenshot. You have undefined references to setup
and loop
In your main.cpp
you have defined a function main()
. Don’t! Not when using the Arduino framework. If you want to code main()
you can’t be doing it in the Arduino framework. If you want to use the Arduino framework, you need to code setup()
and loop()
I think your version of main()
is being (somehow) over-ridden by the Arduino one - you are using the Arduino framework in platformio.ini
, and that version always calls setup()
and loop()
, which don’t appear in your source files. Hence the errors.
This code:
int main()
pinMode(SHOOT_BUTT , INPUT);
pinMode(REL_BUTT , INPUT);
pinMode(SWITCH_BUTT , INPUT);
Serial.begin(9600);
Serial.setTimeout(50);
playerConfig();
for(;;)
receiveData();
displayData();
shootHandler();
reloadHandler();
Should be this:
void setup()
Serial.begin(9600);
playerConfig();
receiveData();
displayData();
shootHandler();
reloadHandler();
(Off the top of my head!)
HTH
Cheers,
Norm.
Also, you have defined this line in Iguns.h
IRsend *irrecvObj;
That header is included in main.cpp
and in Iguns.cpp
hence the error about multiple definitions of ireccvObj
Remove the line from the header file, add it to main.cpp
and add this line to Iguns.cpp
extern IRsend *irrecvObj;
That should fix that error.
Cheers,
Norm.
Thank you! problems with IRsend object are solved, but compiler still returned the collect2.exe error .
Also compiler says that i have undefined reference to loop and setup
(Open image in new tab to see)
Strange! You don’t still have a main
function somewhere, do you?
Cheers,
Norm.
No , i dont have the main function. Maybe its a platformo bug or kind of…
Maybe i should compile it in arduino ide?
It wouldn’t compile there either.
Here is the problem, from main.cpp
namespace MyLaserTag_Gun
Your setup()
and loop()
functions need to be outside of your namespace.
It might work fine if you add using namespace MyLaserTag_Gun;
at the start of main.cpp
, but I would just keep them both out of the namespace.
Cheers,
Norm.
So , i deleted the namespace and … get the collect2.exe error and undefined reference receiveData() function warning. It seems that PlatformIO is kiding on me
Here is the screenshot:
I dont know how , but after // the receiveData() it worked . Thank you for your big feedback. The problem was in this method.
All your functions are in that namespace. If you add using namespace MyLaserTagGun;
you can uncomment it again, it should be fine.
If you don’t add the above, you will need to call them as MyLaserTagGun::receiveData()
etc.
Alternatively, lose the namespace, and the corresponding ‘}’ at the very end of main.cpp
Cheers,
Norm.
