Hello I keep getting this error here is the code im trying to use Marcin648/e90-dashboard-ets2 (github.com)
Im using an arduino Uno
See Declare libraries properly by maxgerhardt · Pull Request #2 · Marcin648/e90-dashboard-ets2 · GitHub
Actually, the error message should not contain “.pio\build\Uno” since the firmware you’ve linked to is for an megaatmega2560
. Make double sure you’ve selected the right project in the first place using the project environment switcher in VSCode.
